missypooofdallas
#1 Posted : 17 years ago
missypooofdallas
Washer will not spin, but does barely agitate intermittently. There is a strange noise coming from the drain pump. What do you think the problem is?
#2 Posted : 17 years ago
The first thing I would do is remove the bottom panel, disconnect the hoses from the drain pump and check for a foreign objects inside.
It suppose to be an envelope with the tech sheets behind this panel and if the drain pump is not the issue, then perform troubleshooting as described in the tech sheets.
- The part number for the drain pump is AP2108083
Here are the break down diagrams for the Frigidaire washer Model GLTF1670AS0
Kaanjii
#3 Posted : 16 years ago
Kaanjii
I followed Gene's directions and removed the pump. My water was not coming out of the washer (Fridgedaire GLTF1670AS0) and I had that wierd noise when it was on the "final Spin" cycle. Luckily for me it was a small 2 inch nail that had stuck in the pump fan and was preventing the pump from spinning. I saved $100 and it only took 1/2 hour of troble shooting because I went to this forum.
Kaanjii@cox.net
#4 Posted : 16 years ago
I'm glad you were able to fix it with no cost to you. Thank you for the feed back.
WPSR3100W1WW - Clothes too wet after spin cycle? (Washer Repair)
by Countryhome 10 months ago
Maytag Washer Doesn't Complete Spin Cycle (Washer Repair)
by glmoore0001 about a year ago
GE WBSR3140DAWW Does not spin during rinse/spin cycle (Washer Repair)
by nj_999 about a year ago
Whirlpool washer spin cycle towels only problem (Washer Repair)
by kylo67 about a year ago
Noise and wobble during spin cycle in top load Whirlpool washer (Washer Repair)
by Guest 2 years ago
Maytag Maxima front load washer hangs on spin cycle (Washer Repair)
by jcross100 2 years ago
MVWC7ESWW0 - jumps to spin cycle (Washer Repair)
Washer banging sides and walks all over when spin cycle (Washer Repair)
Kenmore Washer bounces around on spin cycle (Washer Repair)
by JerryCaldwell 2 years ago
Excessive vibration during spin cycle (Dishwasher Repair)
MAYTAG WASHER NO GOING INTO SPIN CYCLE (Washer Repair)
Whirlpool, grinding badly at end of spin cycle (Washer Repair)
by cdestuck 2 years ago
whirlpool lsc8244bq0 agitates during rince and spin cycle (Washer Repair)
Loud noise at start of spin cycle that stops once at high RPM (Washer Repair)
by tollisal 2 years ago
washer fills with water at spin cycle (Washer Repair)
