I come to the pros once again, you helped me fix the washer now the dryer died out....When you push the start button you hear avery faint sound but nothing moves or happens ?????? :mad:
Open the door. Push and hold the door switch and, while someone else pushing the start button, manually rotate the drum. If it would start then the motor has gone bad. Otherwise post the results. - The dryer motor Part number: AP3094242
