kirkdewitt
#1 Posted : Sunday, August 23, 2009 1:12:16 PM(UTC)
kirkdewitt
The burners still work, but the oven won't light. I thought it might be a bad igniter, but after taking it out and looking at it... it looks fine. Could it still be a bad igniter? How do I test it? It looks like it's just a simple spark plug. Any help on trouble shooting sure would be appreciated!
Thanks,
Kirk
Jim Schweizer
#2 Posted : Thursday, August 27, 2009 11:23:25 AM(UTC)
Jim Schweizer
Thanks,
Kirk
It could be the Oven Valve if the igniter is glowing. If the igniter is not glowing it is either the voltage going to it or it is the valve.
kirkdewitt
#3 Posted : Friday, August 28, 2009 6:31:11 AM(UTC)
kirkdewitt
Thanks Jim, you're right, it was the valve. I've already replaced it and the oven is working and I'm my wife's hero! The ignitor is a sparker type, and it looked fine, so I continued searching and discovered the electrical resistance accross the safety valve was an open circuit instead of the 200 ohms it should have been. Long story short, The info I found on your site was instrumental in tracking down the problem, and I appreciate the help.
Thanks again,
Kirk
Kenmore gas range oven won't work (Oven Repair (including Ranges and Cooktops))
by shirleyjones 12/14/2016 10:41:41 AM(UTC)
oven won't work properly randomly (Oven Repair (including Ranges and Cooktops))
by miklos 9/29/2016 2:36:35 AM(UTC)
by b2bq 6/11/2014 9:26:03 AM(UTC)
Kenmore oven won't work. Stovetop still works but neither bake nor broil will heat (Oven Repair (including Ranges and Cooktops))
by dangole104 2/18/2013 7:22:38 PM(UTC)
GE Built-In Gas Oven Won't Work Even After Replacing Parts (Oven Repair (including Ranges and Cooktops))
by kimpossible 1/17/2013 4:30:57 PM(UTC)
Oven won't work (Oven Repair (including Ranges and Cooktops))
by Hock 6/20/2012 10:30:03 AM(UTC)
Oven won't work after the self cleaning cycle (Oven Repair (including Ranges and Cooktops))
by sluggermike 11/24/2011 12:37:19 AM(UTC)
Kitchen Aid oven won't work after cleaning cycle (Oven Repair (including Ranges and Cooktops))
by geopharmer 3/9/2011 7:18:14 AM(UTC)
Denman please help! Oven won't work. (Oven Repair (including Ranges and Cooktops))
by johnrp99 2/23/2011 12:38:43 PM(UTC)
Maytag Gemini Upper Oven won't work (Oven Repair (including Ranges and Cooktops))
by mleslie 2/21/2011 5:50:47 PM(UTC)
Oven won't work after self-clean. (Oven Repair (including Ranges and Cooktops))
by tandg98 2/21/2011 5:19:51 PM(UTC)
Replaced bake element,but oven won't work (Oven Repair (including Ranges and Cooktops))
by ant1828 2/19/2011 12:52:32 PM(UTC)
Clock & numbers dimming now oven won't work (Oven Repair (including Ranges and Cooktops))
by pennym363 12/21/2010 5:05:46 PM(UTC)
by bmoore201 10/23/2010 7:46:50 AM(UTC)
The bake button of walloven won't work. (Oven Repair (including Ranges and Cooktops))
by jakyl07 8/11/2010 8:42:16 AM(UTC)
