My dryer runs but there is no heat. The timer cycles except on the Automatic setting. There was no glow at the gas ignitor so I replaced it. Still no glow. Any ideas ????? A sensor maybe? Any help would be much appreciated!
It was the thermal fuse!!! Thank you for all the links you posted also. Was a major help. Repaired for less than a service call only! My dryer now runs just like it did before... :)
Originally Posted by: RBYRD9.1  My dryer runs but there is no heat. I Have a Question. My Dryer will run but has no heat. If you put it on a regular cycle it will run all day and all night. I put it on 70 minute dry and it still has no heat but will stop after 70 minutes.. Anyone have a suggestion??:( Thanks
Hi RBYRD9.1,
I'm glad you were able to fix it.
Hi missieann33,
In order to provide the most accurate advise I need the complete model number of the dryer.
Post it as a new thread, please.
My dryer stopped heating again. I have changed the thermal fuse again and the cycling thermostat. It will cycle once and then does not heat again. The ignitor glows but it does not kick in the gas to heat.
Is this the heat coil?
Originally Posted by: RBYRD9.1  ...The ignitor glows but it does not kick in the gas to heat. Is this the heat coil?... Yes, most likely the problem is a bad gas valve coils. Also make sure there is no obstructions in the vent lines and the blower housing is clean. - The part number for the coil kit is AP2150379Gene.
Thanks again Gene! I replaced the coils and the dryer runs and cycles fine now.
You are welcome. Hopefully the problem is solved.
