2 Pages12>
rdarozag
#1 Posted : Thursday, August 13, 2009 7:30:48 AM(UTC)
rdarozag
i change the coupling onthe machine after that was making noise like a ballbearing is broke inside try and smell burning try to check out and now dont trow water or turn in any cycle and make a humming noise
sidfink43
#2 Posted : Friday, August 14, 2009 5:42:19 AM(UTC)
sidfink43
Take off the motor and check to see if you did not press the coupling too close to the transmission, causing the motor to lock up against the transmission shaft that holds the coupling.
rdarozag
#3 Posted: : Friday, August 14, 2009 6:31:23 PM(UTC)
rdarozag
thanks i will look in to that but the washer dont even get water
#4 Posted : Saturday, August 15, 2009 2:44:52 AM(UTC)
You may have blown a fuse or tripped a breaker in the service box in the house.
rdarozag
#5 Posted : Sunday, August 16, 2009 7:08:43 AM(UTC)
rdarozag
is not i fuse the motor make a humming noise but don't star or trow water into the washer
rdarozag
#6 Posted : Wednesday, August 19, 2009 10:49:31 AM(UTC)
rdarozag
the washer agitated but don't pump/drain the water itest the lid and is ok and the switch to only make a humming noise
thanks
#7 Posted : Wednesday, August 19, 2009 12:52:50 PM(UTC)
I would pull the pump and look for a sock stuck in there.
rdarozag
#8 Posted : Thursday, August 20, 2009 6:00:21 AM(UTC)
rdarozag
thanks i will do but went is spinnig make noise like a ball bearing is broke inside
rdarozag
#9 Posted : Monday, August 24, 2009 1:43:02 PM(UTC)
rdarozag
the machine is working until gets hot and stop this happen after i change the coupling and have a burn smell wat can be the problem
thanks
rdarozag
#10 Posted : Monday, August 24, 2009 1:48:03 PM(UTC)
rdarozag
the washer work until gets hot them stop and have a smell of burning this happen after i change the coupling that engage the motor to transmission
thanks
Guest (5)
Older Msytag top load washer main belt tension on model LA612 (Washer Repair)
by Guest 6/29/2024 10:22:44 AM(UTC)
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
GE Top load washer not draining (Washer Repair)
by Guest 6/25/2024 4:59:12 PM(UTC)
Washer won’t spin with load (Washer Repair)
by Guest 6/25/2024 5:32:07 AM(UTC)
Samsung Top Load Washer (Washer Repair)
by welchjames65@hotmail.com 6/21/2024 3:08:07 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 6/13/2024 10:48:53 AM(UTC)
GE Profile Washer not draining and water not hot (Dishwasher Repair)
by Guest 6/8/2024 9:00:21 AM(UTC)
Kenmore washer 110.81821110 (Washer Repair)
by Hitzemup 6/5/2024 3:57:12 PM(UTC)
LG Washer 0E (OE) Error After Pump Motor Replaced (Solved) (Washer Repair)
by kilimar 6/3/2024 2:34:22 PM(UTC)
Whirlpool duet washer front load (Washer Repair)
by Guest 6/3/2024 9:57:09 AM(UTC)
Kenmore 70 series washer grinding (Washer Repair)
by Higginsdog 5/28/2024 4:17:38 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
Kenmore 90 Series top-loader washer won't agitate/drain/spin (fixed?) and makes metallic noise (Washer Repair)
by deepdiver359 5/21/2024 8:09:21 PM(UTC)
GE washer grinding noise (Washer Repair)
by gefixin 5/20/2024 2:01:39 PM(UTC)
2 Pages12>
