2 Pages12>
rdarozag
#1 Posted : 16 years ago
rdarozag
i change the coupling onthe machine after that was making noise like a ballbearing is broke inside try and smell burning try to check out and now dont trow water or turn in any cycle and make a humming noise
sidfink43
#2 Posted : 16 years ago
sidfink43
Take off the motor and check to see if you did not press the coupling too close to the transmission, causing the motor to lock up against the transmission shaft that holds the coupling.
rdarozag
#3 Posted : 16 years ago
rdarozag
thanks i will look in to that but the washer dont even get water
#4 Posted : 16 years ago
You may have blown a fuse or tripped a breaker in the service box in the house.
rdarozag
#5 Posted : 16 years ago
rdarozag
is not i fuse the motor make a humming noise but don't star or trow water into the washer
rdarozag
#6 Posted : 16 years ago
rdarozag
the washer agitated but don't pump/drain the water itest the lid and is ok and the switch to only make a humming noise
thanks
#7 Posted : 16 years ago
I would pull the pump and look for a sock stuck in there.
rdarozag
#8 Posted : 16 years ago
rdarozag
thanks i will do but went is spinnig make noise like a ball bearing is broke inside
rdarozag
#9 Posted : 16 years ago
rdarozag
the machine is working until gets hot and stop this happen after i change the coupling and have a burn smell wat can be the problem
thanks
rdarozag
#10 Posted : 16 years ago
rdarozag
the washer work until gets hot them stop and have a smell of burning this happen after i change the coupling that engage the motor to transmission
thanks
Older Msytag top load washer main belt tension on model LA612 (Washer Repair)
by Guest 8 months ago
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 9 months ago
GE Top load washer not draining (Washer Repair)
by Guest 9 months ago
Washer won’t spin with load (Washer Repair)
Samsung Top Load Washer (Washer Repair)
by welchjames65@hotmail.com 9 months ago
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 9 months ago
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 9 months ago
GE Profile Washer not draining and water not hot (Dishwasher Repair)
Kenmore washer 110.81821110 (Washer Repair)
by Hitzemup 9 months ago
LG Washer 0E (OE) Error After Pump Motor Replaced (Solved) (Washer Repair)
by kilimar 9 months ago
Whirlpool duet washer front load (Washer Repair)
Kenmore 70 series washer grinding (Washer Repair)
by Higginsdog 10 months ago
Dishwasher won't work. (Dishwasher Repair)
by Guest 10 months ago
Kenmore 90 Series top-loader washer won't agitate/drain/spin (fixed?) and makes metallic noise (Washer Repair)
by deepdiver359 10 months ago
GE washer grinding noise (Washer Repair)
by gefixin 10 months ago
2 Pages12>
