Originally Posted by: abadfish66  Redbird and Tami, yes it would be covered....under 3 years old is free. 3-5 years old $100 Can you let me know if my part would be covered GSL25JFRF BS #AL230290 Any information would be greatly appreciated Thank you
Call GE at 1-800-626-2224 or 1-800-626-2005
Thank you Gene for the number. I made an appointment for a sevice call at the GE website and they are coming on Tues. Do you advise me to call the number before they arrive or should I just speak with the service man? Thank you in advance
I would try to get as much as possible information over the phone - it's free!
Aout the only thing free will be the phone call. My fridge did the same thing last night. I too found swollen burnt smelling capacitors and replaced them with some new ones and everhting has been running right on it since. The fix was very easy for me, but I think almost anyone could do it with $3 worth for the 2 capacitors and $20 for a little soldering kit and a solder sucker. I called GE for the free fix and was told they would have to send someone out at my expense around $100 and the board would be free. What?! Told them I am a refrigeration tech and I can change it myself just send me the board and they wouldn't do it! Well, they would send me the board, but they wanted $189 for it!!! What? I can't replace my own "free replacement" board? I still have to pay for their design fault? This just doesn't sit well with me. I have even started to wonder what becomes of those boards when their technician replaces it?
I am having a constant clicking sound, the fan appears to try to turn and then stops. I think the noise is coming from the mother board. model no.GSL251GREBS serial no. VG226743
Thanks- Who do I call and what do I tell them?
Originally Posted by: misstr2  I am having a constant clicking sound, the fan appears to try to turn and then stops. I think the noise is coming from the mother board. model no.GSL251GREBS serial no. VG226743
Thanks- Who do I call and what do I tell them? If you are somehow handy then you probably can fix it yourself, paying only for parts (looks like the main control board and the evaporator fan motor). Otherwise you have to call a certified technician. - The main control board Part number: AP4436216
Just curious if someone can tell me if I qualify for free or discounted main control board replacement ... model - hss25gfphww ... serial rg217570 - any help is greatly appreciated ... Thanks :confused::confused::confused:
Also ... where are folks getting that " WR " control board number , cause I cannot seem to find a WR # anywhere on it ... Thanks :confused::confused::confused:
Originally Posted by: lastsojourner  Just curious if someone can tell me if I qualify for free or discounted main control board replacement ... model - hss25gfphww ... serial rg217570 - any help is greatly appreciated ... Thanks :confused::confused::confused: Unfortunately the only place where you can get all such information is GE. Quote:Call GE at 1-800-626-2224 or 1-800-626-2005 Gene.
