jackssib1
#1 Posted : Thursday, August 6, 2009 8:49:55 AM(UTC)
jackssib1
i CAN'T FIND THE DEFROST TIMER. Can anyone tell me where I can find it.? It is not listed on diagram, for this mod.:mad:
Plzzzz
THANKS
JACK
I need to know where the defrost timer is located. I don't see it in Diagram, Mod.# GSS201EMA WW, GE.
#2 Posted : Thursday, August 6, 2009 1:16:36 PM(UTC)
Re-post and state your problem.
jackssib1
#3 Posted : Thursday, August 6, 2009 3:11:40 PM(UTC)
jackssib1
I have went trough all the steps and down to the timer. but I don't know where it is located. Heater -ok, evaporator coils cleaned,defrost thermostat, ok so now i'm looking for the timer,,lol
Jack, mod. #GSS201EMA WW,,,,GE.
#4 Posted : Friday, August 7, 2009 12:36:50 AM(UTC)
Unplug refrigerator, remove the cover of the motherboard in the back of fridg, and remove the 4 pin power connector from the pc board. Check which pc board pins are labled Line and defr. On the removed connector, put a jumper between the related pins. Plug the fridg in.The freezer heater should now heat up. If not, replace the heater and defrost thermostat. If it defrosts, replace the motherboard.
Heater, AP4355467, defrost thermostat AP3884317, Motherboard AP3420506
You have no manual defrost control on this fridg.
jackssib1
#5 Posted : Friday, August 7, 2009 3:15:16 AM(UTC)
jackssib1
I do have manual defrost control on this fridg. It is on the control knob , turn freezer to 0 it heats up.
Jack
Jump defrost timer (Refrigerator & Freezer Repair)
by baechlem 4/21/2020 12:21:48 PM(UTC)
Can't find the defrost timer (Refrigerator & Freezer Repair)
by Ardee348 3/14/2020 12:52:47 PM(UTC)
Refrigerator defrost timer (Refrigerator & Freezer Repair)
by Cabob 3/12/2019 5:38:53 AM(UTC)
Defrost Timer Setting (Refrigerator & Freezer Repair)
by Rattletrap45 11/21/2018 5:30:39 AM(UTC)
Defrost timer ready to defrost and blows circuit breaker (Refrigerator & Freezer Repair)
by DeweyBoo 6/6/2018 5:18:48 PM(UTC)
Refrigerator shuts off after replacing defrost timer (Refrigerator & Freezer Repair)
by Blaine211 9/13/2017 4:44:33 PM(UTC)
Frigidaire defrost timer (Refrigerator & Freezer Repair)
by Jefe60 9/9/2017 1:57:46 PM(UTC)
setting a defrost timer (Refrigerator & Freezer Repair)
by e4g76 6/30/2017 1:15:41 PM(UTC)
Where is the defrost timer located on Amana ARS2667AW (Refrigerator & Freezer Repair)
by f117b2 6/9/2017 4:55:09 AM(UTC)
GE Fridge running a little hot bad defrost timer/compressor? (Refrigerator & Freezer Repair)
by Maddrnkm 4/14/2017 3:27:39 PM(UTC)
by rt4x4 4/4/2017 9:01:48 AM(UTC)
New defrost timer requires tap to start (Refrigerator & Freezer Repair)
by Donro 10/5/2016 8:37:14 AM(UTC)
I don't see a defrost thermostat, nor a defrost timer. (Refrigerator & Freezer Repair)
by JoeH55 8/12/2016 10:06:09 AM(UTC)
Defrost timer stops turning (Refrigerator & Freezer Repair)
by Defroster 7/31/2016 1:24:37 PM(UTC)
Four defrost timers ALL bad? (Refrigerator & Freezer Repair)
by Defroster 12/6/2015 7:30:28 PM(UTC)
