TPK
#1 Posted : Thursday, August 6, 2009 7:36:27 AM(UTC)
TPK
My GE washer (WHDSR316GOWW) agitates fine, but spins very slowly so the clothes stay dripping wet. I checked the lid switch...its' OK. Pump works and drain is clear. Belt appears in good shape. It simply does not kick into a high speed spin. I'm thinking its the timer or perhaps a solenoid problem? :confused:
Suggestions greatly appreciated!
sidfink43
#2 Posted : Saturday, August 8, 2009 3:17:11 PM(UTC)
sidfink43
Take off the front and observe the motor and drive pulley in the spin mode and see if you can determine what is happening.
Also, this machine has error codes from the flashing light on the motor. Here is a site which will enable you to see if you are getting an error code. Some errors cause the machine to slow the spin.
HydroWave GE Washer Repair Guide
TPK
#3 Posted : Tuesday, August 11, 2009 7:56:14 AM(UTC)
TPK
Thanks! I did not notice the tiny flashing light before. It was blinking 9 times indicating that the break resistor failed. If it was a true failure, the motor would have had to been replaced. However, we were able to reset/clear it this time by unplugging the machine for 20 seconds, plugging it back in, and then opening/closing the lid 5 times. Now it works fine! Thanks so much again. Great service.
sidfink43
#4 Posted : Tuesday, August 11, 2009 1:06:37 PM(UTC)
sidfink43
Your experience if fairly common withy this model. Glad you got it going again.
Thanks for updating us.
Whirlpool washer spins slowly and noisily (Washer Repair)
by chuckledog 3/3/2017 6:26:54 AM(UTC)
Fridgidaire Affinity Washer Spins slowly (Washer Repair)
by quichua007 4/16/2015 12:26:02 AM(UTC)
Estate Washer spins slowly (Washer Repair)
by Draven53365 5/7/2014 8:53:38 AM(UTC)
Washer Spins Slowly (Washer Repair)
by dabowler 7/26/2013 6:24:03 AM(UTC)
Whirlpool Washer spins SLOWLY even after putting in new clutch (Washer Repair)
by babaasheri 1/15/2013 5:24:11 PM(UTC)
Maytag washer spins slowly (Washer Repair)
by rickw51 5/8/2012 1:36:10 PM(UTC)
washer spins slowly and doesn't drain large load (Washer Repair)
by kbarnitz 4/19/2010 9:09:58 AM(UTC)
Washer Spins slowly stops and restarts (Washer Repair)
by eegone 3/15/2010 8:01:08 PM(UTC)
