renaemil
#1 Posted : Monday, August 3, 2009 4:59:13 PM(UTC)
renaemil
:confused: My maytag washer model LAT9206BAE will wash, and drain but will not spin. Someone told me it was probably the bearing, another said something must be jammed between the tub and the drum. What do you thing could be the problem.
My email address is: renaemil@nbnet.nb.ca
Than your very much:)
magician59
#2 Posted : Monday, August 3, 2009 7:40:03 PM(UTC)
magician59
A very common cause of this problem is either a tripped out-of -balance switch (corrected by fully opening the lid until you hear it "click" back into place), or a faulty lid switch.
renaemil
#3 Posted : Tuesday, August 4, 2009 1:59:28 AM(UTC)
renaemil
:confused: Thank you for your response however I do not think that the lid switch is the problem because when I put the control knob to the spin position I can hear the motor trying to spin the tub and it does not spin. The problem has to be something else.
Thank you
#4 Posted : Tuesday, August 4, 2009 3:30:39 AM(UTC)
Will the motor stop humming after a short period of time?
renaemil
#5 Posted : Tuesday, August 4, 2009 12:02:10 PM(UTC)
renaemil
The motor is labouring, trying to spin the tub and it starts smelling burning rubber because the motor pulley is spinning and overheating the belt
#6 Posted : Tuesday, August 4, 2009 1:43:57 PM(UTC)
Pull the plastic cover off the top of the tub and check for something in the tub. If ok, you probably have jammed brake shoes, or worn pulley cam washers.
Maytag Legacy top load washer not spinning (Washer Repair)
by Guest 10/28/2023 8:56:04 AM(UTC)
Whirlpool washer Not spinning 6/21/23 (Washer Repair)
by yveron 6/21/2023 11:33:50 AM(UTC)
Whirlpool WTW4800BQ0 Washer Not Spinning (Washer Repair)
by MrTryToFixIt 12/1/2022 8:20:20 AM(UTC)
frigidaire washer not spinning out clothes (Washer Repair)
by tadthebass 3/24/2020 8:51:55 AM(UTC)
MAYTAG MHWC7500Y WASHER NOT SPINNING AT HIGH SPEED (Washer Repair)
by ehbrown1 11/5/2019 4:50:11 AM(UTC)
Stacked Maytag/Neptune Washer not spinning (Washer Repair)
by Building and Grounds 10/24/2017 12:26:37 PM(UTC)
GE Profile washer not spinning (Washer Repair)
by LSUStephen 7/16/2017 1:25:43 PM(UTC)
Whirlpool washer not spinning fast (Washer Repair)
by AmyM269 9/3/2016 4:22:47 PM(UTC)
Maytag Washer not spinning / draining (Washer Repair)
by retho78 5/21/2016 5:29:56 AM(UTC)
GE Washer not spinning (Washer Repair)
by zoobteach 8/29/2015 10:12:50 AM(UTC)
by atomicsynth 6/2/2015 10:36:31 PM(UTC)
Kenmore 70 Series washer not spinning (Washer Repair)
by workingdad 2/21/2015 7:31:47 PM(UTC)
Whirlpool washer not spinning or agitating; blowing breaker (Washer Repair)
by ejditz3 8/4/2014 1:15:39 PM(UTC)
GE washer not spinning any cycle (Washer Repair)
by j409 6/2/2014 7:44:19 AM(UTC)
Washer not spinning after replacing Thrust Bearing Kit (Washer Repair)
by Woody Williams 2/25/2014 2:06:33 PM(UTC)
