bkillian
#1 Posted : 16 years ago
bkillian
My over the range microwave just stopped heating food. Everything else works and there is no buzzing noise. Just sounds normal when in use. I was working some yesterday but it was almost at though it was taking longer to cook however now nothing.
mainfloral
#2 Posted : 16 years ago
mainfloral
Our microwave suddenly stopped heating. It is a ge and 9 years old. I'm hoping that you can tell me what part you think I need to repair it. Thanks Main Floral
#3 Posted : 16 years ago
Originally Posted by: bkillian Go to Quoted Post
...I was working some yesterday but it was almost at though it was taking longer to cook however now nothing...
Check the power at the outlet. It suppose to be 120 VAC ± 10% under a load. If it's less then the microwave would not work.
If there is nothing wrong then the problem most likely is a bad magnetron.
- The magnetron Part number: AP3846818
#4 Posted : 16 years ago
What is the complete model number of the microwave?
Does it make any unusual noise? Does the light, the cooling fan and the turntable still work?
mainfloral
#5 Posted : 16 years ago
mainfloral
It is a GE model #JVM1660WB00-3 It does not make any unusual noise and the light and cooling fan still work. Thanks for your help! main floral
#6 Posted : 16 years ago
Remove the top grill. Open the control panel. Discharge the high voltage capacitor. Remove the wires from the high voltage transformer primary windings and check for 120 VAC between these wires while the control calls for heat and the door is closed.
If there is no proper voltage then the problem most likely is a bad control board.
If there is 120 VAc reading then the magnetron is the culprit.
- The magnetron Part number: AP2631638
- The control board Part number: AP2631621
Chungster
#7 Posted : 16 years ago
Chungster
Thanks Gene... I was thinking about a new microwave over before I read your post. I followed your instructions and it was the magnatron after all. It was questionable since it read ok. However, since I did get the 115V going to the primary side of the transformer. It was either it or the magnatron. Many thanks...Chungster
#8 Posted : 16 years ago
You are welcome. I'm glad you were able to fix it. Thank you for your feed back and good luck with your microwave.
mainfloral
#9 Posted : 16 years ago
mainfloral
which red wire goes to the magnatron. thanks main floral
#10 Posted : 16 years ago
I'm afraid I did not get it clear.
Samsung dryer stopped heating (Dryer Repair)
by Jakesnow 4 years ago
Counter Top Microwave Stopped Heating (Microwave Repair)
by Olibaba 10 years ago
Kenmore Dryer stopped heating. (Dryer Repair)
by willow5000 10 years ago
Whirlpool Dryer stopped heating (Dryer Repair)
by jambla 11 years ago
6EM40-2 Richmond 240V electric WH stopped heating (Heating, Ventilation, and Air Conditioning (HVAC))
by gb77 11 years ago
Kenmore stopped heating (Dryer Repair)
by aag3981 11 years ago
Frigidaire microwave stopped heating (Microwave Repair)
by darrenwelson 11 years ago
by jrnutpaul 11 years ago
dryer stopped heating and runs non stop (Dryer Repair)
by jescousa 12 years ago
GE Profile Microwave stopped heating food. (Microwave Repair)
by jackief288 13 years ago
Top wall oven stopped heating (Oven Repair (including Ranges and Cooktops))
by JVP01USA 13 years ago
Dryer Stopped Heating Up (Dryer Repair)
by rrblk 13 years ago
Microwave/Oven stopped heating (Microwave Repair)
by bowentd 13 years ago
Microwave just stopped heating (Microwave Repair)
by richardduncan 14 years ago
Whirlpool Estate Dryer Stopped Heating (Dryer Repair)
by kimyoung 14 years ago
