repair12
#1 Posted : Saturday, July 25, 2009 11:43:12 AM(UTC)
repair12
refrigerator portion will not get cold ?
Freezer is working fine
magician59
#2 Posted : Saturday, July 25, 2009 12:49:02 PM(UTC)
magician59
Remove the back panel inside the freezer compartment and see if there is a heavy frost build-up on the evaporator coil.[COLOR="Red"] Do not remove frost by physical scraping.[/COLOR] If there is a lot of frost, you have a defrost problem. Report your findings, and we'll help you through the diagnosis and repair.
bbutler
#3 Posted : Sunday, July 26, 2009 9:57:08 AM(UTC)
bbutler
the coils were froze
bbutler
#4 Posted : Sunday, July 26, 2009 9:59:09 AM(UTC)
bbutler
magician59
#5 Posted : Sunday, July 26, 2009 1:55:29 PM(UTC)
magician59
Do you own a meter? Can you do some simple resistance and continuity tests? When it thaws, tell us about the condition of the defrost thermostat (the round device about the diameter of a nickel or quarter, clipped to the evaporator coil: Is it swollen?
frigidaire wall oven 6564063 (Oven Repair (including Ranges and Cooktops))
by Guest 7/2/2024 12:40:53 PM(UTC)
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
Frigidaire fill tube leak: Is it just a bad design? (Refrigerator & Freezer Repair)
by bobhucker 6/18/2024 7:59:46 AM(UTC)
Frigidaire oven won’t heat (Oven Repair (including Ranges and Cooktops))
by Jseeders 6/16/2024 10:23:51 AM(UTC)
Frigidaire FGHT2055VF - light switch? (Refrigerator & Freezer Repair)
by ranger58 6/13/2024 11:14:06 AM(UTC)
Frigidaire Gallery Refridgerator (Dishwasher Repair)
by Guest 6/10/2024 9:18:21 AM(UTC)
Frigidaire FFHB2740PS2 No Power (Refrigerator & Freezer Repair)
by mnjeepmale 6/3/2024 5:19:45 AM(UTC)
Frigidaire French door temperature (Refrigerator & Freezer Repair)
by Guest 5/28/2024 4:10:07 AM(UTC)
Frigidaire PLHS238ZCB1 Refigerator compressor issues. (Refrigerator & Freezer Repair)
by TonyMertz 5/18/2024 9:32:13 PM(UTC)
Frigidaire oven issue (Dishwasher Repair)
by Guest 5/8/2024 12:45:18 PM(UTC)
Frigidaire Gallery dripping through water dispenser (Refrigerator & Freezer Repair)
by cascodo 5/6/2024 9:26:01 PM(UTC)
Frigidaire FFHT1835VB1 Stuck in Defrost Mode (Refrigerator & Freezer Repair)
by dcuozzo 5/6/2024 9:55:29 AM(UTC)
Frigidaire Affinity front loader code (Washer Repair)
by Volusiacrazy 5/1/2024 3:26:17 AM(UTC)
Frigidaire max load top load washer (Washer Repair)
by Guest 4/29/2024 9:02:43 AM(UTC)
Frigidaire fgus2642lf2 auger not getting power (Refrigerator & Freezer Repair)
by knmens 4/15/2024 6:17:43 PM(UTC)
