bbatey
#1 Posted : Wednesday, July 22, 2009 8:07:16 AM(UTC)
bbatey
When I try to turn on the dryer with the starter switch (turns to the right, then back) it just humms. I took the motor plate off and the drum turns OK, not sure about the motor. Could this just be the starter switch?
sidfink43
#2 Posted : Thursday, July 23, 2009 4:26:50 PM(UTC)
sidfink43
On the GE's it is probably going to be the motor. Try to manually get the dryer to turn by having a friend push the start switch while you push in the door switch and manually turn the drum. BE CAREFUL!!! If it starts, you are going to need a new motor.
If you want more info and advice please post the full model number
bbatey
#3 Posted : Friday, July 24, 2009 6:55:00 AM(UTC)
bbatey
Thanks for your reply. To my dispay, I thought it might be the starter switch and I removed it, now I cannot put it back because two little metal bars fell out and I don't know how to put them back. If I manage to get them back in, I will try your method.
Bevelry Batey
Starter switch problem (Washer Repair)
by Nunner 12/13/2015 5:04:51 PM(UTC)
Fried Starter Switch (Dryer Repair)
by waldenr03 7/23/2012 11:44:26 AM(UTC)
GE Starter Switch Removal (Dryer Repair)
by joes75 11/21/2011 11:32:09 AM(UTC)
compressor starter switch installation hookup (Refrigerator & Freezer Repair)
by gregdarby 4/20/2011 2:56:42 PM(UTC)
Dryer will not keep running after I let go of the starter switch (Dryer Repair)
by greg13 4/18/2011 3:21:15 PM(UTC)
installing a starter switch (Refrigerator & Freezer Repair)
by Carol Doorn 2/14/2011 9:46:14 AM(UTC)
Starter switch - humming sound (Dryer Repair)
by cmbohler 6/8/2010 9:47:02 AM(UTC)
