I need to remove the starter switch to replace it. My question is how does the switch(small black box) remove from the panel. I see its held in with 2 metal prongs on 2 sides and theres a small 1 inch bracket extending from it? The part # WE4M519 (I ordered didnt get it) looks like it comes with the metal bracket. thanks joes75 attached the following image(s):
Upon further inspection I see that the metal arm lifts up and then you have to twist(unlock) the actual switch to get it out. ;)
