joe7777
#1 Posted : Tuesday, July 21, 2009 7:13:50 AM(UTC)
joe7777
The other day i turned the lamps on and there was a blue flash ,as if there was a short. Now they do not work at all. I removed the cover and traced the wire,but dont see any burnt section .Is there a fuse that controls this,or what do i need to fix it? The microwave runs fine except for the lamp problem. joe
my email is terezina@aol.com
#2 Posted : Tuesday, July 21, 2009 3:47:13 PM(UTC)
Check if there is 120 VAC to the lights while the control calls for the surface light.
If there is proper voltage then just replace the light bulbs. Do not forget to unplug the microwave before you do it.
If there is no proper voltage then the control board has to be replaced.
- The light bulb Part number: AP2029997
- The control board Part number: AP2631591
Microwave problem (Microwave Repair)
by Klemire123 1/4/2018 9:35:53 AM(UTC)
Whirlpool Microwave problems? (Microwave Repair)
by jpmxr111 12/23/2012 12:07:51 PM(UTC)
Sticky Microwave problem (Microwave Repair)
by ldwalker 5/3/2011 6:19:06 PM(UTC)
Whirlpool gold microwave problem (Microwave Repair)
by pasricat 7/26/2010 8:49:52 AM(UTC)
Microwave problems (Microwave Repair)
by Ralph357 5/21/2010 8:38:01 AM(UTC)
Frigidaire Microwave Problem (Microwave Repair)
by qztfwq 5/18/2010 10:28:42 AM(UTC)
Electrolux Microwave Problems... (Microwave Repair)
by SteveWSC 5/4/2010 8:33:06 AM(UTC)
Weird Microwave Problem (Microwave Repair)
by steevzter 3/13/2010 10:32:35 AM(UTC)
by andreamazzario 7/25/2009 4:34:46 PM(UTC)
Kenmore Elite Microwave Problem (Microwave Repair)
by dmeyer710 1/10/2009 8:07:57 AM(UTC)
microwave problems (Microwave Repair)
by mimiki 1/15/2008 4:16:19 PM(UTC)
by shortblok 11/27/2007 7:53:14 AM(UTC)
