mrlhunter
#1 Posted : Sunday, July 12, 2009 12:16:20 PM(UTC)
mrlhunter
I have amana alw480daw , belt burned up this morning and I would like to know why the belt burned up?
:cool: Do you think the motor is gong out or the pump is bad ? How do I determin what the problem is, could you send me a diagram on how to replace belt?
#2 Posted : Sunday, July 12, 2009 4:52:23 PM(UTC)
Either a bad pump, or bad tub bearings, just check, most probably the pump.
mrlhunter
#3 Posted : Monday, July 13, 2009 10:39:54 AM(UTC)
mrlhunter
rich checked pump and I can turn pully to pump and wheel under tub. turned on machine and water pumps into tub but unable to turn agitator in the tub.
Should I be able to turn the agitator, keep inmind that I still havn't installed new belt. If I cant spin agitator would that mean the trans. is froze up?
Steveh
#4 Posted : Wednesday, July 22, 2009 3:40:55 PM(UTC)
Steveh
I had the same problem. Do be aware that the belt needs to be a cloth covered belt to allow for slippage. If your trany is failed, it will be covered under waranty. If the main berring is failed, it is not. That's per Amana.
Front Loader washing machine will not fill. E5E error code. (Washer Repair)
by jjuly 7/3/2024 12:25:33 PM(UTC)
GE Top Loader Washing Machine Leaking from bottom (Washer Repair)
by Guest 6/13/2024 9:46:30 AM(UTC)
whirlpool washing machine model wtw57esvw0 (Washer Repair)
by Guest 5/7/2024 7:57:17 AM(UTC)
Help! Washing machine on repeat rinse cycle (Washer Repair)
by cali.poppy 4/29/2024 9:08:28 AM(UTC)
Frigidaire Affinity Washing Machine - Leaking only sometimes (Washer Repair)
by omf_24 2/24/2024 4:45:41 PM(UTC)
Stem question about Naytag 2-belt washing machine (Washer Repair)
by Hotrodjohn71 1/2/2024 7:50:48 AM(UTC)
Maytag Oasis HE Washing Machine (Washer Repair)
by Guest 12/8/2023 12:55:45 PM(UTC)
Whirlpool Washing Machine won't start/fill (Washer Repair)
by greekguy7 12/8/2023 4:53:34 AM(UTC)
whirlpool model wtw7300dw2 washing machine (Washer Repair)
by Guest 11/8/2023 9:27:17 AM(UTC)
MVWB965HC0 Washing Machine - Need Service Manual or Video to Replace Touchpad and Control Assembl (Washer Repair)
by Guest 10/30/2023 8:11:10 PM(UTC)
Best vintage, American made washing machines (Washer Repair)
by Guest 10/30/2023 5:27:34 AM(UTC)
Washing machine not washing clothes properly (Washer Repair)
by Guest 9/20/2023 11:56:24 AM(UTC)
Washing Machine fill with water but will not spin, rinse or agitate. (Washer Repair)
by jmaiso 9/1/2023 7:04:07 AM(UTC)
Washing machine do not complete the cycle (Washer Repair)
by Guest 8/16/2023 10:02:15 AM(UTC)
Mayag washing machine - possibly locked motor? (Washer Repair)
by crp0499 5/19/2023 3:02:19 AM(UTC)
