hello,
dryer will not heat,
checked the thermal fuse, it has continuity.
can i get more detailed info on checking the other components.
There was a death in the family yesterday and we expect sevaral house guests starting later today, to stay at our house.
A quick and detailed answer would be greatly appreciated.
I need this now like a hole in the head.
i removed the heating element and measure an open across the two terminal with the wires disconnected, i guess that is bad.
Is that correct, what should it read?
No continuity across the heating element terminals means the heating element is bad. - The heating element Part number: AP3094254
That was it. Found one in stock up the road and replaced, all is well again.
Thanks a lot for the input.
