tdma
#1 Posted : Friday, July 10, 2009 5:18:09 AM(UTC)
tdma
hello,
dryer will not heat,
checked the thermal fuse, it has continuity.
can i get more detailed info on checking the other components.
There was a death in the family yesterday and we expect sevaral house guests starting later today, to stay at our house.
A quick and detailed answer would be greatly appreciated.
I need this now like a hole in the head.
tdma
#2 Posted : Friday, July 10, 2009 5:52:22 AM(UTC)
tdma
i removed the heating element and measure an open across the two terminal with the wires disconnected, i guess that is bad.
Is that correct, what should it read?
#3 Posted : Friday, July 10, 2009 10:17:44 PM(UTC)
No continuity across the heating element terminals means the heating element is bad.
- The heating element Part number: AP3094254
tdma
#4 Posted : Saturday, July 11, 2009 1:20:33 AM(UTC)
tdma
That was it. Found one in stock up the road and replaced, all is well again.
Thanks a lot for the input.
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
no heat from oven or broiler (Oven Repair (including Ranges and Cooktops))
by lennyag 1/5/2024 1:41:07 PM(UTC)
Dryer loud squeaking and no heat (Dryer Repair)
by hackerfam 11/2/2023 10:52:15 AM(UTC)
LG Dryer DLE2301R No Heat (Dryer Repair)
by mhess01 10/19/2023 4:56:37 PM(UTC)
No heat when assembled (Dryer Repair)
by Guest 8/16/2023 3:44:03 AM(UTC)
whirlpool PN# W10339417; no heating after replacing element (Oven Repair (including Ranges and Cooktops))
by Guest 7/13/2023 12:27:07 PM(UTC)
Whirlpool Duet Electric dryer - no heat (Dryer Repair)
by ShawnDS24 2/25/2023 9:08:24 AM(UTC)
No heat, (Dryer Repair)
by tseibring 1/8/2023 7:57:44 AM(UTC)
Brand New LG gas dryer , GAS code, no heat (Dryer Repair)
by lglad 11/24/2022 7:24:02 PM(UTC)
Gas Dryer GE GFDS355GL0MS No Heat. Ignitor is good E11 error. (Dryer Repair)
by jim.starzynski@gmail.com 7/5/2022 6:35:29 PM(UTC)
Dryer starts, does not stop, no heat (Dryer Repair)
by Guest 6/28/2022 11:03:33 AM(UTC)
Samsung Electric Range-No Heat (Oven Repair (including Ranges and Cooktops))
by Jimh64 6/27/2022 8:39:17 AM(UTC)
Samsung Dryer DV448AEP/XAC - no heat (Dryer Repair)
by mgmjtech 5/18/2022 8:22:27 PM(UTC)
heeat turns on no heat comming up through floor register (Heating, Ventilation, and Air Conditioning (HVAC))
by Guest 2/6/2022 2:57:49 PM(UTC)
