awest
#1 Posted : Thursday, July 9, 2009 4:35:54 PM(UTC)
awest
Stove is showing error code F1, will not reset after unplugging. Display panel will not allow any commands can not resest time etc., any commmands bake/broil...beeping sound w/F1 error code. This started when the oven was being used to broil...when the oven was turned on there was baking pans in the oven. Is it possible that the heat from the pans damaged something in the oven to cause this to happen?
kayakcrzy
#2 Posted : Friday, July 10, 2009 4:48:29 AM(UTC)
kayakcrzy
Originally Posted by: awest Go to Quoted Post
stove is showing error code f1, will not reset after unplugging. display panel will not allow any commands can not resest time etc., any commmands bake/broil...beeping sound w/f1 error code. this started when the oven was being used to broil...when the oven was turned on there was baking pans in the oven. is it possible that the heat from the pans damaged something in the oven to cause this to happen?
no, it just happens. you need to replace the clock control board. tom
LG LMXS30776S/03 refer error code F1 (Refrigerator & Freezer Repair)
by FishinBob 12/9/2022 8:36:17 AM(UTC)
Fridgidaire Range Error code F10. (Oven Repair (including Ranges and Cooktops))
by 22pistol 3/2/2017 5:18:33 PM(UTC)
Whirlpool error code f1e2 (Washer Repair)
by Melodyvanatti 2/16/2017 8:32:38 AM(UTC)
Lid lock flashing - error code F1 E2 (Washer Repair)
by burritoman 8/22/2016 4:53:48 PM(UTC)
Frigidaire error code f11 (Oven Repair (including Ranges and Cooktops))
by bbcci 8/9/2013 4:45:22 AM(UTC)
Whirlpool Wash Error Code F11 (Washer Repair)
by majorbourne 4/29/2013 6:13:55 PM(UTC)
Error code F10? (Oven Repair (including Ranges and Cooktops))
by cs86 3/16/2013 12:20:48 PM(UTC)
Whirlpool Cambrio Automatic washer error code F1 (Washer Repair)
by dishwasher6 7/24/2012 4:46:21 PM(UTC)
Error Code F13 (Oven Repair (including Ranges and Cooktops))
by George Karschney 3/21/2012 11:24:28 AM(UTC)
Jenn air error code F1 (Oven Repair (including Ranges and Cooktops))
by hkillgore 3/13/2012 8:19:48 AM(UTC)
Error Code F1 Oven Range (Oven Repair (including Ranges and Cooktops))
by jcorral 1/17/2012 12:50:23 AM(UTC)
Error code F11 (Washer Repair)
by pgeden 7/28/2011 6:05:13 AM(UTC)
oven error code F1 E1 (Oven Repair (including Ranges and Cooktops))
by nollrsv3 4/2/2011 1:30:38 AM(UTC)
thermador c302 oven error code f19 (Oven Repair (including Ranges and Cooktops))
by toniofoz 3/1/2011 4:27:44 PM(UTC)
Error Code F1 E3 (Oven Repair (including Ranges and Cooktops))
by viceroy 2/19/2011 1:48:54 PM(UTC)
