pgeden
#1 Posted : Thursday, July 28, 2011 6:05:13 AM(UTC)
pgeden
Error code F11; Even after resetting it keeps happening; Is there a common fix?
Jeff / APP Team
#2 Posted : Thursday, July 28, 2011 7:48:41 AM(UTC)
Jeff / APP Team
Hello pgeden. The F11 code if for a faulty motor controller unit.
Possible Causes/Procedure
- Verify the shipping system including shipping bolts and spacers are removed,
and power cord out of the unit.
- Check if washer is on a dedicated circuit. Other devices on same circuit can create
line noise and cause this issue.
- Unplug washer or disconnect power
- Check the neutral feed to the MCU and CCU from the AC line filter.
- Check all wire harness connections between the Motor & MCU, and MCU to CCU,
are not broken or wires detached and connector internal pins are visible.
- Make sure that all the connectors are fully seated.
- Plug in washer or reconnect power cord.
If all of this is good, you will need to replace the motor controller. Hope this helps.
Part number: AP3861856
Frigidaire error code f11 (Oven Repair (including Ranges and Cooktops))
by bbcci 8/9/2013 4:45:22 AM(UTC)
Whirlpool Wash Error Code F11 (Washer Repair)
by majorbourne 4/29/2013 6:13:55 PM(UTC)
kenmore elite gas stove error code F11 (Washer Repair)
by dolesen 10/1/2009 7:32:18 AM(UTC)
Error code F11 (Washer Repair)
by crashline 9/1/2009 4:32:24 AM(UTC)
