I just replaced the clock/timer electronic display and plugged the stove back in and keep getting a F11 error code. What does this mean?
Groups: APP Team
Hello. Disconnect the ribbon from the control panel and clean it using pencil eraser. then carefully reconnect it. if the F11 is still there most likely it's the control panel. The panel Part number: AP3910768
I'm sorry that your question wasn't answered on time. Although, it's probably too late to help you, I'm posting the answer anyway, so that it may help other people with a similar problem. Thank you. Simon.
