i get error code F1 E1 evry time i try using oven i select bake then it showes up 350 as temp then start indicator flashes then i select start and then error code F1 E1 and beeper what can i do thanks in advance :confused:
Originally Posted by: nollrsv3  i get error code F1 E1 evry time i try using oven i select bake then it showes up 350 as temp then start indicator flashes then i select start and then error code F1 E1 and beeper what can i do thanks in advance :confused: come on guys i really need help with this one ! an only 1 irrelevant reply??? im in the used appliance buiseness and can be of great help here as iv been doing this for 25+ years i dont have manuel to get codes any help would be greatly appreaciated !!!!:rolleyes:
