I am receiving a F1 error code along with an audible beep. This requires a reset at the power supply. This returns the unit to a functional state for a brief time. Can you tell me what to test or what the code means?
Groups: APP Team
Hello. F1 error code means - bad control board. There is no tests required, basically you need to replace the control board. See the attached diagram #2, position #2. The control board Part number: AP4397547
