My dryer runs fine but does not heat when drying. I was wondering what it could be and how to check the parts to know what is wrong. I do not have the manual for it so need to know how to get to the parts as well.
Hi Shea
If the dryer does not heat you either have electrical problems or gas problems.
You will need to partially disassemble your dryer to get to the electrical fuses/thermostats, which you will have to check for continuity.
If they check out, review the postings on this Forum for checking gas components (I am not a gas man) and they will give you good guidance, as there are only a few thing which can go wrong.
If you click on your model number you will get exploded diagrams with the parts you need to fix it.
Good luck
