Rebound
#1 Posted : Friday, July 3, 2009 2:35:16 PM(UTC)
Rebound
Condenser fan motor dosen't run when compressor runs. It runs if red and yellow wires are jumped. Could this be a bad mother board? Symptoms were intermittent poor cooling and very hot front cabinet on both sides of the freezer compartment. Condenser coils are clean. When fan is jumped, problem clears.
woodchuckie
#2 Posted : Friday, July 3, 2009 4:06:54 PM(UTC)
woodchuckie
Yes it probably is the mother board. You may can find brown or burnt areas on it showing it's bad or you may not be able to tell but the motherboard does control the fans and you know it works. Part 801 on diagram 8. Replacement parts for GE GSS20IEPAWW | AppliancePartsPros.com
Rebound
#3 Posted : Sunday, July 5, 2009 6:44:52 AM(UTC)
Rebound
What voltage should there be to the condenser fan motor?
woodchuckie
#4 Posted : Sunday, July 5, 2009 2:07:19 PM(UTC)
woodchuckie
The replacement on the diagram for your model is a dc motor so it should be 12 volts.
Rebound
#5 Posted : Sunday, July 5, 2009 5:24:22 PM(UTC)
Rebound
I'm sure it's the board as you said in an earlier post. Just want to ask a few more, with your permission. I have three wires in the harness going to the motor. A red, a white and a yellow. I have 13vdc across the red and white. I have 13vdc across the red and yellow. Zero across the yellow and white. I'm not sure I understand why when I jump the red and yellow, the motor runs. Any thoughts? Thanks for your time and patience.
woodchuckie
#6 Posted : Monday, July 6, 2009 5:39:54 AM(UTC)
woodchuckie
The middle one is a ground and the job of the board is to complete the circuit so it will run. You are completing the circuit on the fan end. I think your fan is good but you can also test in for continuity on the ohm setting on the meter. Place a probe on each terminal. the middle one is for ground and does not need to be tested. The multitester should display a reading approximately mid-way between infinity and zero ohms.
Rebound
#7 Posted : Sunday, July 19, 2009 2:17:34 PM(UTC)
Rebound
Thanks for all the help. Received the new board, followed instructions on cutting the jumper wire and all is well. There are two additional cable terminal connections on the new board, but are clearly marked and are not need on my unit. Do you know how I can get a schematic for this unit? Thanks again. RJ
Need to test Condenser Fan motor on GE Monogram (Refrigerator & Freezer Repair)
by Rmr882 8/25/2023 8:01:36 PM(UTC)
matching specs for replacement condenser fan motor (Heating, Ventilation, and Air Conditioning (HVAC))
by rleescott 7/22/2022 5:12:15 AM(UTC)
Emerson 2198747 Whirlpool Condenser Fan Motor (Refrigerator & Freezer Repair)
by Spectrum 11/24/2018 2:26:34 PM(UTC)
Fridge/Freezer Buzzing, condenser fan motor running hot (Refrigerator & Freezer Repair)
by minvac 10/14/2013 5:51:52 PM(UTC)
condenser fan motor works lying down but not upright (Refrigerator & Freezer Repair)
by KLH1 7/3/2013 8:38:19 AM(UTC)
How to replace condenser fan motor for whirlpool ed25dw (Refrigerator & Freezer Repair)
by DKC56 12/5/2011 10:31:46 AM(UTC)
condenser fan motor airflow (Refrigerator & Freezer Repair)
by rmnj 11/26/2011 9:14:29 PM(UTC)
Kenmore Condenser fan motor replacement woes.. (Refrigerator & Freezer Repair)
by shippey 8/20/2011 4:55:02 AM(UTC)
magic chef fridge condenser fan motor (Refrigerator & Freezer Repair)
by 95peterbuilt 8/25/2010 6:12:45 PM(UTC)
condenser fan motor intermittantly staying off (Refrigerator & Freezer Repair)
by kjstephe 6/13/2010 6:53:47 PM(UTC)
Testing Condenser Fan Motor (Refrigerator & Freezer Repair)
by Fxitpop 6/13/2010 3:54:30 PM(UTC)
Condenser Fan Motor Replacement P/N 240397101 shaft will not hold the fan straight (Refrigerator & Freezer Repair)
by racerjack 5/5/2010 2:35:27 PM(UTC)
Condenser Fan Motor not working (Refrigerator & Freezer Repair)
by scieslicki 9/26/2009 6:01:41 AM(UTC)
GE refrigerator - bad condenser fan motor? (Refrigerator & Freezer Repair)
by hurricanelt78 7/14/2008 2:18:50 PM(UTC)
Condenser fan motor not working (Refrigerator & Freezer Repair)
by Magilla Gorilla 7/8/2008 12:28:32 PM(UTC)
