Leon Wittner
#1 Posted : Tuesday, October 9, 2007 8:32:14 AM(UTC)
Leon Wittner
In April 2006 our Whirlpool dishwasher started leaking water at the bottom right hand side of the door. It stopped leaking until recently and started again. Is this a door seal problem or could it be something else? Sometimes it is a smal drip and other times it leaks more. Is the door seal hard to replace and does it come with directions for replacement?
snakeman56
#2 Posted : Monday, December 31, 2007 12:16:25 PM(UTC)
snakeman56
Did you ever find out what the problem was? Mine is doing the same thing! I just ordered the door gasket and see if that helps.
Leon Wittner
#3 Posted : Monday, December 31, 2007 2:13:22 PM(UTC)
Leon Wittner
My leak was caused due to the pump cover shifting allowing water to blow out and spay up under the front of the door panel. I puled the spray arm off and removed the plastic cover from the pump well sump. There is a big rubber "O" Ring that had come out and was allowing the pressure to blow out instead of going to the upper spray arm. I reiserted the "O" Rong and put the top back on and it stopped the problem. Hope this helps you byt it fixed the problem for me. I did not need the new door seal but it is new anyway.
Whirlpool -Dishwasher - Middle Rack not getting clean/door leak (Dishwasher Repair)
by Guest 11/30/2023 5:53:50 PM(UTC)
Bottom seal of front door leaking on model #DW80F600UTS (Dishwasher Repair)
by Guest 12/21/2022 3:13:56 PM(UTC)
Diswaser door leak (Dishwasher Repair)
by S T 5/26/2021 10:19:50 AM(UTC)
Whirlpool dishwasher door leak (Dishwasher Repair)
by Guest 5/26/2021 9:40:52 AM(UTC)
Frigisaire FGIP2468UF0A door leak (Dishwasher Repair)
Belarus jeff1casey 11/23/2020 11:15:45 AM(UTC)
SOLVED: Dishwasher door leak (Dishwasher Repair)
by raulk 7/4/2020 12:48:46 PM(UTC)
GE GDF570SSF0SS Dishwasher Door Leak (Dishwasher Repair)
by Ericsd2 1/2/2019 2:17:44 PM(UTC)
Door leak after replacing door seal boot (Washer Repair)
by SCO300 3/2/2017 1:16:14 PM(UTC)
Frigidaire Dishwasher: door leaking from top of panel when open for Loading (Dishwasher Repair)
by MrsLyons07 12/21/2015 9:06:37 AM(UTC)
dishwasher door leaks (Dishwasher Repair)
by lavern1935 12/1/2015 12:14:41 PM(UTC)
KitchenAid dishwasher door leak (Dishwasher Repair)
by edburnsmd 3/23/2015 4:03:39 PM(UTC)
bottom of door leaking (Dishwasher Repair)
by rocky303 3/9/2015 6:57:22 AM(UTC)
Door Leaking (Dishwasher Repair)
by Littleking 8/10/2014 1:39:40 PM(UTC)
Maytag Dishwasher has door leak (Dishwasher Repair)
by NoName12 6/25/2014 6:35:49 PM(UTC)
Door Leak on LG Dishwasher LDF6920ST (Dishwasher Repair)
by snapline 9/8/2013 8:10:01 AM(UTC)
