KitchenAid stainless dishwasher KDFE104DBL2 bought Jan 2016. Kondone door gasket W10300924 ($19) installed Jun 2020.
After about four a half years I noticed several drops of water on floor below bottom right of the door after a wash. Assumed it was the door gasket so bought/installed new gasket. Leak continued, actually a little worse. I did a thorough inspection.
Observations: 1.Seam at top center of gasket track had 1/16" gap. 2.Gasket track 1/16" gap at upper right curve against inner wall. 3.New gasket (Kondone) is thicker/heavier than original.
Actions: 1.JBWaterWeld epoxy putty to fill gaps at top center seam and upper right curve (avoiding putty in the gasket track). 2.Reinstalled original (used) gasket.
Result: 1.No leak.
Conclusions/Opinions/Assumptions/Unknowns: 1.Water forced behind gasket track through the gaps bypassed the primary sealing surface. 2.Replacement gasket being heavier/thicker was less flexible than original so could not conform as readily to non-uniform track. 3.I do not know if the Kondone replacement is thicker than the more expensive factory replacement. 4.I do not know if the gasket-track gaps were original or have widened over the years, but the leak has stopped so I'm happy.
