gailb
#1 Posted : Monday, June 29, 2009 6:09:02 AM(UTC)
gailb
ice maker has a continous flow of water. owners manual is no help, only covers hook-up to water supply.:confused:
woodchuckie
#2 Posted : Monday, June 29, 2009 7:19:24 AM(UTC)
woodchuckie
The water inlet valve may be staying open.
You can swap the wires on the dual water inlet valve and disconnect the water line at the valve which goes to the ice maker.
When you try the water dispenser the water will come out there.
When you stop the water dispenser, if the water at the valve doesn't stop, the valve isn't closing so you'll need to replace it.
If it does stop after trying it several times then the problem is with the ice maker.
gailb
#3 Posted : Tuesday, June 30, 2009 5:07:42 AM(UTC)
gailb
how do i get to it?? is it in the front where you pull off the little square cover?? thx--g.
gailb
#4 Posted : Tuesday, June 30, 2009 5:09:33 AM(UTC)
gailb
:confused:
woodchuckie
#5 Posted : Tuesday, June 30, 2009 5:35:40 AM(UTC)
woodchuckie
It's on the back where the water supply comes in. May be behind the cardboard cover o the left side.
Kenmore Ice maker power line check (Refrigerator & Freezer Repair)
by Surfmob 6/25/2020 8:02:40 AM(UTC)
Kenmore Ice Maker (Refrigerator & Freezer Repair)
by Charba 6/2/2016 7:10:02 AM(UTC)
Kenmore ice maker not producing (Refrigerator & Freezer Repair)
by rashillinger@hotmail.com 4/20/2016 9:23:18 AM(UTC)
Kenmore Ice Maker and Ice Door Not working (Refrigerator & Freezer Repair)
by Austex_Egger 2/15/2016 7:25:22 PM(UTC)
Kenmore ice maker won't dispense cubes (Refrigerator & Freezer Repair)
by patlocke 5/21/2014 9:13:21 AM(UTC)
Kenmore ice maker is not working (Refrigerator & Freezer Repair)
by jthreatt 3/4/2013 8:11:46 AM(UTC)
Kenmore ice maker leak, tried everything! (Refrigerator & Freezer Repair)
by Bgmwd 7/6/2012 6:35:14 PM(UTC)
Kenmore Ice Maker not making Ice (Refrigerator & Freezer Repair)
by ghauptman 5/25/2012 1:47:12 PM(UTC)
Kenmore ice maker not making ice (Refrigerator & Freezer Repair)
by rswareing 5/4/2012 8:49:05 AM(UTC)
Kenmore Ice Maker overflowing with water (Refrigerator & Freezer Repair)
by splumer 3/26/2012 5:33:13 AM(UTC)
Kenmore Ice maker - no water (Refrigerator & Freezer Repair)
by mbowman44 12/17/2011 3:47:12 PM(UTC)
Kenmore ice maker flap door will not auto close... (Refrigerator & Freezer Repair)
by Choski 2/19/2011 7:54:17 PM(UTC)
Kenmore ice maker not working (Refrigerator & Freezer Repair)
by jimajr 12/23/2010 7:29:56 PM(UTC)
Replace control board for whirlpool/kenmore ice maker (Refrigerator & Freezer Repair)
by molee@watanabenason.com 6/18/2010 10:24:00 AM(UTC)
by ldutton 5/1/2010 8:15:32 AM(UTC)
