kool-lites
#1 Posted : Saturday, June 27, 2009 2:13:32 PM(UTC)
kool-lites
greetings from a wet Sydney Australia.
The dryer blower wheel failed mid winter last season and has only just been replaced.
I also replaced the roller wheels as one had disintegrated. took the opportunity to also replace the front slides.
now the dryer is back in service it seems to run and stop mid cycle. pushing the start button won't restart the dryer. I suspect the High Temp thermostat is cutting in.
When I had the dryer in pieces , I wasn't sure if the motor is completely up to scratch as it didn't turn freely. However have no idea how freely it should turn.
Any suggestions on what I should check?
if a new one is required, AP4043522 ( 50Hz) is probably the one i need to source, however can some tell me if it is a 240Vac unit.
BTW, you might ask why ask this from Australia- Maytag parts are hard to buy here, I purchased all my parts direct from USA. the warranty servicing was at best poor, more likely very sub-standard.
cheers
Matt
magician59
#2 Posted : Saturday, June 27, 2009 3:52:13 PM(UTC)
magician59
Wish you could send some of that rain up to Houston, Texas! Sounds like you may need to replace that motor. Without a belt attached, it should turn rather freely. It's probably cutting out on heat overload.
GE Spacemaker electric washer dryer stops mid cycle (Dryer Repair)
by nikolait 3/6/2022 11:35:53 PM(UTC)
GE Dishwasher lights up but won't start, or stops mid cycle (Dishwasher Repair)
by tbiz20 12/16/2020 10:56:06 AM(UTC)
Whirlpool Gold Stops mid cycle (Dishwasher Repair)
by sryan17 9/21/2017 6:19:55 PM(UTC)
Washer stops mid cycle (Washer Repair)
by NevadaBill 7/3/2017 7:54:11 AM(UTC)
Stops mid cycle (Washer Repair)
by syager48 6/13/2017 3:59:37 PM(UTC)
Whirlpool Gas Dryer screaching noise at first, then stops mid cycle (Dryer Repair)
by SRALPH 12/14/2016 11:40:34 AM(UTC)
washer stops mid cycle (Washer Repair)
by postal13 4/18/2016 4:38:15 PM(UTC)
Roper Dryer Stops Mid Cycle (Dryer Repair)
by bradford0113 1/26/2016 6:08:16 AM(UTC)
Whirlpool LSC8244BQ0 Washer - stops mid cycle (Washer Repair)
by ydono 9/21/2015 10:05:30 AM(UTC)
Washer numbers flash, stops after hitting start, stops mid cycle (Washer Repair)
by BrianM245shopping 7/8/2015 1:07:22 PM(UTC)
GE washer stops mid cycle (Washer Repair)
by APPLIANCEDUDE1972 3/4/2015 6:32:45 AM(UTC)
Stops mid cycle with "Start/Reset" light blinking (Dishwasher Repair)
by far2wise 2/22/2015 4:03:38 PM(UTC)
Kenmore Dryer stops mid cycle, restarts immediately (Dryer Repair)
by mrdance123 9/11/2014 2:56:36 PM(UTC)
Kitchenaid superbra stops mid cycle (Dishwasher Repair)
by CarolynE 3/31/2014 5:12:12 PM(UTC)
Maytag Epic Dryer stops mid cycle on auto (Dryer Repair)
by sjacobs4 12/10/2013 10:20:06 AM(UTC)
