Our Duet washer will stop in mid cycle and flash error codes E01/F03 which we found to be a problem with the water pump. We ordered and installed water pump thinking this would fix the problem, but is hasn't. We did find a small piece of electrical fitting in the pump filter that looked burnt, but assumed it was part of the old pump. It still flashes the same codes in the middle of the cycle. It seems to fill excessively with water so the sensing of the weight of the water doesn't get recognized. What now? Are there a way to clear codes or is it the water valve? Not sure what to do. Please help?
