Washer goes thro cycles fine, but when it gets to the spin cycle the tub rotates a couple times back and forth and shuts off. Have run diagnostic and tub will spin proberly during test but comes up with E47 error. Tested door latch as per test 9 and came up the proper ohms. Changed the main control, same problem. Changed the motor control, same problem. Any suggestions what I need to try next. Running out of clean clothes!
A faulty door lock is one of the most common problems with this kind of the washers. You may want to check the wire harness between the lock and the control board. Make sure the door is closing properly and the door striker engaging the door lock. If there is nothing wrong, replace the door lock even if it did pass the test. - The door lock Part number: AP4455026
Thanks Gene
Replaced door lock and washer working fine. Should of came here first.
You are welcome. I'm glad you were able to fix it.
