Freezer not cooling
Refrigerator & Freezer Repair
I have a Frigidaire freezer model FFFH17F2QWA thatís under 2 years old. Two weeks ago I noticed water on the
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer not cooling
  #1 (permalink)
Old 04-13-2017, 08:45 AM
Junior Member
dave27 is on a distinguished road
Default Freezer not cooling
Model Number: FFFH17F2QWA   Brand: Frigidaire   Age: 1 - 5 years
I have a Frigidaire freezer model FFFH17F2QWA thatís under 2 years old. Two weeks ago I noticed water on the floor below the door. Items on the top shelf were only partially frozen. I pulled the metal panel off from in front of the evaporator coil. No frost build-up on the coils. There was frozen water in the drain channel as well as the drain. After removing the ice build-up and confirming that the drain wasnít plugged I temporarily replaced the panel. The freezer has been cooling to the extreme (dial thermometer almost pegged out as low as it can go).
Sunday I put the panel screws back and noticed that in removing the panel I had set the thermostat to the coldest setting (7) so I moved it down to 5. The drain again had an ice plug which I again melted and confirmed again that the drain was working. This morning the compressor wasnít on and items on the top shelf were only partially frozen. Thermometer was right at 32 degrees F. I upped the thermostat to the next coldest setting (6), nothing. A few minutes later I set it to the coldest setting (7). Compressor kicked on and the sides of the freezer got warm indicating the freezer was cooling off. Iím guessing the thermostat is bad?
Related Models
Frigidaire FFGC2605LWA COOKTOP
Frigidaire FFGC3005LWA COOKTOP
Frigidaire FFGC3015LBA COOKTOP
Frigidaire FFGC3015LBB COOKTOP
Frigidaire FFGC3015LSA COOKTOP
Frigidaire FFGC3015LSB COOKTOP
Frigidaire FFGC3015LWA COOKTOP
Frigidaire FFGC3015LWB COOKTOP
Frigidaire FFGC3025LBA COOKTOP
Frigidaire FFGC3025LBB COOKTOP
Frigidaire FFGC3025LSA COOKTOP
Frigidaire FFGC3025LSB COOKTOP
Frigidaire FFGC3025LWA COOKTOP
Frigidaire FFGC3025LWB COOKTOP
Frigidaire FFGC3603LWA COOKTOP
Frigidaire FFGC3625LBA COOKTOP
Frigidaire FFGC3625LBB COOKTOP
Frigidaire FFGC3625LSA COOKTOP
Frigidaire FFGC3625LSB COOKTOP
Frigidaire FFGC3625LWA COOKTOP
Frigidaire FFGC3625LWB COOKTOP
Frigidaire FFGF3000MWA GAS RANGE
Frigidaire FFGF3005MQA GAS RANGE
Frigidaire FFGF3005MWA GAS RANGE
Frigidaire FFGF3011LBA GAS RANGE
Frigidaire FFGF3011LBB GAS RANGE
Frigidaire FFGF3011LBC GAS RANGE
Frigidaire FFGF3011LWA GAS RANGE
Frigidaire FFGF3011LWB GAS RANGE
Frigidaire FFGF3011LWC GAS RANGE
Frigidaire FFGF3013LBA GAS RANGE
Frigidaire FFGF3013LBB GAS RANGE
Frigidaire FFGF3013LBC GAS RANGE
Frigidaire FFGF3013LBD GAS RANGE
Frigidaire FFGF3013LWA GAS RANGE
Frigidaire FFGF3013LWB GAS RANGE
Frigidaire FFGF3013LWC GAS RANGE
Frigidaire FFGF3013LWD GAS RANGE
Frigidaire FFGF3015LBA GAS RANGE
Frigidaire FFGF3015LBB GAS RANGE
Frigidaire FFGF3015LBC GAS RANGE
Frigidaire FFGF3015LBD GAS RANGE
Frigidaire FFGF3015LMA GAS RANGE
Frigidaire FFGF3015LMB GAS RANGE
Frigidaire FFGF3015LMC GAS RANGE
Frigidaire FFGF3015LMD GAS RANGE
Frigidaire FFGF3015LWA GAS RANGE
Frigidaire FFGF3015LWB GAS RANGE
Frigidaire FFGF3015LWC GAS RANGE
Frigidaire FFGF3015LWD GAS RANGE
Frigidaire FFGF3017LBA GAS RANGE
Frigidaire FFGF3017LBB GAS RANGE
Frigidaire FFGF3017LBC GAS RANGE
Frigidaire FFGF3017LBD GAS RANGE
Frigidaire FFGF3017LSB GAS RANGE
Frigidaire FFGF3017LSC GAS RANGE
Frigidaire FFGF3017LWA GAS RANGE
Frigidaire FFGF3017LWB GAS RANGE
Frigidaire FFGF3017LWC GAS RANGE
Frigidaire FFGF3017LWD GAS RANGE
Frigidaire FFGF3019LWA GAS RANGE
Frigidaire FFGF3019LWB GAS RANGE
Frigidaire FFGF3019LWC GAS RANGE
Frigidaire FFGF3019LWD GAS RANGE
Frigidaire FFGF3021LBA GAS RANGE
Frigidaire FFGF3021LBB GAS RANGE
Frigidaire FFGF3021LBC GAS RANGE
Frigidaire FFGF3021LWA GAS RANGE
Frigidaire FFGF3021LWB GAS RANGE
Frigidaire FFGF3021LWC GAS RANGE
Frigidaire FFGF3023LBA GAS RANGE
Frigidaire FFGF3023LBB GAS RANGE
Frigidaire FFGF3023LBC GAS RANGE
Frigidaire FFGF3023LMA GAS RANGE
Frigidaire FFGF3023LMB GAS RANGE
Frigidaire FFGF3023LMC GAS RANGE
Frigidaire FFGF3023LQA GAS RANGE
Frigidaire FFGF3023LQB GAS RANGE
Frigidaire FFGF3023LQC GAS RANGE
Frigidaire FFGF3023LSA GAS RANGE
Frigidaire FFGF3023LSC GAS RANGE
Frigidaire FFGF3023LWA GAS RANGE
Frigidaire FFGF3023LWB GAS RANGE
Frigidaire FFGF3023LWC GAS RANGE
Frigidaire FFGF3027LBA GAS RANGE
Frigidaire FFGF3027LBB GAS RANGE
Frigidaire FFGF3027LSA GAS RANGE
Frigidaire FFGF3027LSB GAS RANGE
Frigidaire FFGF3027LSC GAS RANGE
Frigidaire FFGF3027LWA GAS RANGE
Frigidaire FFGF3027LWB GAS RANGE
Frigidaire FFGF3047LSA GAS RANGE
Frigidaire FFGF3047LSB GAS RANGE
Frigidaire FFGF3047LSC GAS RANGE
Frigidaire FFGF3047LSD GAS RANGE
Frigidaire FFGF3047LSE GAS RANGE
Frigidaire FFGF3049LSA GAS RANGE
Frigidaire FFGF3049LSB GAS RANGE
Frigidaire FFGF3049LSC GAS RANGE
Frigidaire FFGF3049LSD GAS RANGE
Frigidaire FFGF3049LSE GAS RANGE
Frigidaire FFGF3051LSA GAS RANGE
Frigidaire FFGF3051LSB GAS RANGE
Frigidaire FFGF3051LSC GAS RANGE
Frigidaire FFGF3051LSD GAS RANGE
Frigidaire FFGF3051LSE GAS RANGE
Frigidaire FFGF3051LSF GAS RANGE
Frigidaire FFGF3053LSA GAS RANGE
Frigidaire FFGF3053LSB GAS RANGE
Frigidaire FFGF3053LSC GAS RANGE
Frigidaire FFGF3053LSD GAS RANGE
Frigidaire FFGF3053LSE GAS RANGE
Frigidaire FFGF3053LSF GAS RANGE
Frigidaire FFGS3025LBA GAS RANGE
  #2 (permalink)
Old 04-30-2017, 03:51 PM
Junior Member
I replaced the thermostat and the unit is working again.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Refrigerator/Freezer stops cooling, then starts cooling, then stops cooling angiebritt Refrigerator & Freezer Repair 4 05-16-2016 05:31 AM
Iced behind freezer back panel. Freezer and Fridge not cooling, temp around 50F guanacux Refrigerator & Freezer Repair 2 01-22-2014 10:37 AM
GE Profile Refrigerator W/ Bottom Freezer - Fridge Cooling Fine, Freezer Issues Javaair Refrigerator & Freezer Repair 0 09-02-2013 06:06 PM
top freezer amana not cooling freezer or fridge rexdart Refrigerator & Freezer Repair 0 01-05-2013 12:08 PM
refridgerator not cooling. freezer is cooling fine Debbie Ash Refrigerator & Freezer Repair 0 08-24-2011 10:17 AM
