dave27
#1 Posted : Thursday, April 13, 2017 7:45:39 AM(UTC)
dave27
I have a Frigidaire freezer model FFFH17F2QWA that’s under 2 years old. Two weeks ago I noticed water on the floor below the door. Items on the top shelf were only partially frozen. I pulled the metal panel off from in front of the evaporator coil. No frost build-up on the coils. There was frozen water in the drain channel as well as the drain. After removing the ice build-up and confirming that the drain wasn’t plugged I temporarily replaced the panel. The freezer has been cooling to the extreme (dial thermometer almost pegged out as low as it can go).
Sunday I put the panel screws back and noticed that in removing the panel I had set the thermostat to the coldest setting (7) so I moved it down to 5. The drain again had an ice plug which I again melted and confirmed again that the drain was working. This morning the compressor wasn’t on and items on the top shelf were only partially frozen. Thermometer was right at 32 degrees F. I upped the thermostat to the next coldest setting (6), nothing. A few minutes later I set it to the coldest setting (7). Compressor kicked on and the sides of the freezer got warm indicating the freezer was cooling off. I’m guessing the thermostat is bad?
dave27
#2 Posted : Sunday, April 30, 2017 2:51:17 PM(UTC)
dave27
I replaced the thermostat and the unit is working again.
GE botom freezer not cooling (Refrigerator & Freezer Repair)
by Dieselista 10/6/2023 5:39:30 PM(UTC)
Samsung family hub freezer not cooling (Refrigerator & Freezer Repair)
by foster1447 8/20/2023 2:36:12 PM(UTC)
Refrigerator working, freezer not cooling (Refrigerator & Freezer Repair)
by Guest 7/11/2023 6:24:54 AM(UTC)
Freezer not cooling, compressor is hot (Refrigerator & Freezer Repair)
by hsafar 6/28/2020 7:09:45 AM(UTC)
Fridge and Freezer not cooling enough (Refrigerator & Freezer Repair)
by DannyC77 4/26/2020 8:55:35 PM(UTC)
Samsung RF34H9960S4 freezer not cooling (Refrigerator & Freezer Repair)
by cndesu 11/29/2019 12:12:30 PM(UTC)
Kitchen Aid Refridg/Freezer not cooling?freezing (Refrigerator & Freezer Repair)
by meeksmansfield 10/12/2018 7:21:35 AM(UTC)
GE side by side refrigerator freezer not cooling (Refrigerator & Freezer Repair)
by ReddogRudy 6/10/2018 3:21:06 PM(UTC)
Frig/Freezer Not Cooling/Overflowing Drain Pan (Refrigerator & Freezer Repair)
by merc1100sc 10/16/2017 7:38:46 AM(UTC)
Refrigerator/Freezer Not Cooling (Refrigerator & Freezer Repair)
by sytipton 7/18/2017 12:39:26 PM(UTC)
frige and freezer not cooling well (Refrigerator & Freezer Repair)
by echamp 6/26/2017 8:34:34 AM(UTC)
Fridge and freezer not cooling (Refrigerator & Freezer Repair)
by tommydoggett 4/6/2017 9:39:13 AM(UTC)
GE pfs22sisbss freezer not cooling, replaced control board (Refrigerator & Freezer Repair)
by lewisl 3/29/2017 10:10:00 AM(UTC)
Refridgerator/Freezer not cooling enough (Refrigerator & Freezer Repair)
by blbrchnk 12/15/2016 5:08:53 AM(UTC)
Whirlpool Refrigerator/Freezer not cooling Intermittenly (Refrigerator & Freezer Repair)
by mshilko 9/14/2016 9:33:30 AM(UTC)
