I like to know how to remove the front cover assembly of the ice and water despenser?
Remove the drip tray. This will expose a couple screws. The plastic outer flange then will slide up off the door clips.
Thank you for responding. I appreciate your reply but on this model it doesn't have any screws under the drip try.
Originally Posted by: djpinersdjpiners Thank you for responding. I appreciate your reply but on this model it doesn't have any screws under the drip try. Carfully look for any hidden screws. If you find none, then lift the unit up to disengage the holding clips.
Originally Posted by: alecponting The first flush is a simple effective method of removing insects, bird droppings & other debris every time it rains, by washing it into the 1st Flush, where the ball float seals it in and debris settles to the bottom. first flush you answered to the wrong questiin.
