trapperone
#1 Posted : Monday, May 17, 2010 6:27:37 AM(UTC)
trapperone
When I cooked beakfast oven worked fine, when I put roast in oven to cook it glowed orange but burner did not come on.
tried to turn on broiler & set it on hi, clock came back on which it does not when broiling
kayakcrzy
#2 Posted : Tuesday, May 18, 2010 3:50:03 AM(UTC)
kayakcrzy
The ignitor coil is bad. That is the part that glows. It is not glowing bright enough to open ther gas valve. Replace it, and you will fresh biscuits in the morning. Tom ApplianceEducator.com - Parts
Bosch Bottom Oven Doesn't work (Oven Repair (including Ranges and Cooktops))
by sc1984 3/28/2020 11:37:27 AM(UTC)
Whirlpool Electric Oven Doesn't Work (Oven Repair (including Ranges and Cooktops))
by pandrada 10/17/2016 3:58:07 AM(UTC)
Maytag MES5752BAS oven doesn't work after self clean (Oven Repair (including Ranges and Cooktops))
by myovensucks 9/9/2015 7:35:53 AM(UTC)
Oven doesn't work at all (Oven Repair (including Ranges and Cooktops))
by AngieR 3/13/2014 10:32:10 AM(UTC)
clock flashes 12:00 and oven doesn't work (Oven Repair (including Ranges and Cooktops))
by enossr 11/14/2013 6:19:35 AM(UTC)
Oven doesn't work (Oven Repair (including Ranges and Cooktops))
by vonholbrook 4/8/2013 11:50:12 AM(UTC)
by Jleering 1/22/2013 5:49:21 AM(UTC)
Frigidaire - loud pop now oven doesn't work (Oven Repair (including Ranges and Cooktops))
by chansman 1/11/2013 3:49:34 PM(UTC)
bake function of gas oven doesn't work (Oven Repair (including Ranges and Cooktops))
by luckobucko 12/16/2012 9:08:18 AM(UTC)
My oven doesn't work (Oven Repair (including Ranges and Cooktops))
by David19 9/24/2012 5:50:52 PM(UTC)
Thermador-Oven doesn't work after self clean (Oven Repair (including Ranges and Cooktops))
by Skyvu 3/13/2012 11:08:26 AM(UTC)
Control Panel and Oven Doesn't Work (Oven Repair (including Ranges and Cooktops))
by cfun 12/2/2011 12:59:19 PM(UTC)
Kitchen Aid dual fuel range, oven doesn't work (Oven Repair (including Ranges and Cooktops))
by bkvanbek 9/26/2011 5:16:43 PM(UTC)
magic chef oven doesn't work (Oven Repair (including Ranges and Cooktops))
by davidhelminski 6/6/2011 12:44:20 PM(UTC)
Oven doesn't work, but range and broiler do (Oven Repair (including Ranges and Cooktops))
by jconway1968 11/29/2010 7:33:54 AM(UTC)
