tlrplus@comcast.net
#1 Posted : Friday, December 18, 2009 6:50:30 AM(UTC)
tlrplus@comcast.net
Dryer not heating up. Replaced heating element. Still does not heat up. Any suggestions what else it could be.
#2 Posted : Friday, December 18, 2009 8:35:04 AM(UTC)
Replacement parts for WHIRLPOOL TEDX640PQ1 29"electric Dryer | AppliancePartsPros.com
Here is the wiring diagram
http://www.servicematters.com/d...0Sheet%20-%208576793.pdf
Have you checked the power at the plug, L1 to L2 should be 240 volts.
Ir the timer does not advance in timed dry mode then this may be your problem as the timer in this unit uses 240 volts.
Check the operating thermostat, hi-limit thermostat and the thermal fuse.
1998 Maytag Gas Dryer Drum Issue Has Me Stumped (Dryer Repair)
by semaas 4/22/2024 9:44:18 PM(UTC)
Whirlpool gas dryer model WGD8300SW2 (Dryer Repair)
by Guest 4/20/2024 7:14:50 AM(UTC)
WED4815EW1 Dryer overheating? (Dryer Repair)
by Guest 4/16/2024 12:21:03 PM(UTC)
DLEX5780WE lg dryer shutting off before the clothes are dry. (Dryer Repair)
by LMA 4/13/2024 11:00:21 AM(UTC)
help maytag comercial dryer (Dryer Repair)
by blackwell316 4/4/2024 5:05:48 PM(UTC)
grease for rear dryer bearing (Dryer Repair)
by bronn033 3/30/2024 12:57:30 PM(UTC)
Kenmore Gas Dryer Running Hot (Dryer Repair)
by Guest 3/30/2024 6:24:53 AM(UTC)
Kenmore 100 dryer Heating Element (Dryer Repair)
by postalservice21 3/27/2024 6:43:17 AM(UTC)
Maytag electric dryer model MDE6400AYQ (Dryer Repair)
by Guest 3/25/2024 10:05:21 AM(UTC)
GE Dryer Timer and Housing (Dryer Repair)
by Guest 3/25/2024 7:47:59 AM(UTC)
Samsung dryer motor (Dryer Repair)
by Guest 3/24/2024 11:17:52 AM(UTC)
Replacement dryer motor W11364931 (Dryer Repair)
by Guest 3/23/2024 8:47:41 AM(UTC)
Maytag electirc dryer model LDE9334ACM (Dryer Repair)
by Guest 3/22/2024 6:07:19 PM(UTC)
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
Electric Dryer Amana NED7300WW1 (Dryer Repair)
by AlexanderK 3/13/2024 1:37:06 PM(UTC)
