Hello, I just recently replaced the rear bearing on my aeq6000es2 Frigidaire dryer. It was making a different sound now, so I took it apart again and changed out all of the felt seals, rear pulley and the plastic glides. Nearly all of the grease from the rear ball socket leaked out. I used all that came from the kit. What can I use to lube this? High temp grease?
Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0 Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Best lube to use is a high temperature wheel bearing grease but not too much.
Groups: Moderators, APP Team, Registered Joined: 2/27/2024(UTC) Posts: 0 Location: TN Was thanked: 9 time(s) in 9 post(s)
The hi-temp lubricant used in the rear bearing kit is part number 5303307893.
