bradboykin84
#1 Posted : Tuesday, November 13, 2012 10:29:12 AM(UTC)
bradboykin84
I have a whirlpool electrice range. Model GY397LXU. I recently had an issue with the oven not heating to temp. I tested the Ohms on the Temp probe @ 72° ambient temp. The ohms read correctly. I had continuity on the bake element. However, when the oven was on, the power to the elements would cycle on for a few seconds and then off for a few. I ordered a new control board for the range and installed it today. Plugged the range back in and turned the oven on to 300°. The oven made it to 290° and started cycling power off to the control board. This model has a didigtal clock and readout. While cycling it will flash the time and 290° for a split second four times total. Then it will turn completely off for approx. 10 seconds and then flash it again. This repeated until I turned the breaker off and left it off to reset. I turned the breaker back on and set the oven temp to 250°. It heated to temp without any issues, but when I open the door, it cycled off like it did earlier until I closed the door back. Any help would be greatly appreciated.
Whirlpool Electric Range Cooktop Will not Heat (Oven Repair (including Ranges and Cooktops))
by mraupie17 9/2/2023 9:50:45 AM(UTC)
Problem with Whirlpool electric range (won't heat properly anymore) (Oven Repair (including Ranges and Cooktops))
by phillydee 4/20/2023 6:10:35 AM(UTC)
Whirlpool electric range GR563LXSS (Oven Repair (including Ranges and Cooktops))
by longtimealaskan 3/6/2023 9:47:00 PM(UTC)
Strange Whirlpool Electric Range Problem and Quandry (Oven Repair (including Ranges and Cooktops))
by TheDoctorsCompanion 1/6/2015 6:26:01 PM(UTC)
Whirlpool electric range oven (Oven Repair (including Ranges and Cooktops))
by king1 6/22/2014 5:11:19 AM(UTC)
Whirlpool Electric Range LR cooktop not working (Oven Repair (including Ranges and Cooktops))
by binw022@yahoo.com 2/18/2013 5:53:12 AM(UTC)
Whirlpool Electric Range (Oven Repair (including Ranges and Cooktops))
by JWhiteOH@aol.com 3/14/2012 6:00:15 PM(UTC)
Replaced Control Panel on Whirlpool Electric Range but there is nothing (Oven Repair (including Ranges and Cooktops))
by lheidema 6/5/2011 7:20:00 PM(UTC)
Whirlpool Electric Range Not Heating Up (Oven Repair (including Ranges and Cooktops))
by Mikecass 5/2/2011 12:36:25 PM(UTC)
Whirlpool Electric Range doesn't work (Oven Repair (including Ranges and Cooktops))
by Holmes59 3/17/2011 8:17:28 AM(UTC)
Whirlpool electric range - Oven (Bake light) does not stay ON (Oven Repair (including Ranges and Cooktops))
by dieselgg 11/16/2008 11:23:04 AM(UTC)
by jschee 3/19/2008 3:21:12 PM(UTC)
