sinkerking
#1 Posted : Thursday, March 29, 2012 10:09:03 AM(UTC)
sinkerking
I have a Beaumark Energy Star front load washing machine. It wont spin except for a small jerk once it gets to the spin on the timer. The door lock is acting up and wont unlock and the timer wont advance past certain points. I took the front and back panels off and looked at the Tech sheet. It said to measure the voltages between the 5 and 6 pins in the 6 pin plug. I did and it read 0. It said to check the timer line switch or the door lock. I removed the door lock and tried testing in for continuity, the meter just read OL but i'm not exactly sure if I'm checking it right or if this is even the problem. Any advice?
#2 Posted : Thursday, March 29, 2012 12:50:48 PM(UTC)
You have to measure the wax motor (the orange piece on the right side of the following picture) circuit resistance. The normal reading is about 1500 Ohms. Otherwise the door lock has to be replaced.
- The door lock assembly Part number: AP4455026
sinkerking
#3 Posted : Thursday, March 29, 2012 12:58:27 PM(UTC)
sinkerking
That is the part I checked, I'm still trying to figure out my digital multimeter - on one setting (M"ohm") it reads .875, but on another setting (just the "ohm" symbol) it only reads OL.
Do you think that is the problem? The door lock? Or something else.
#4 Posted : Thursday, March 29, 2012 1:52:37 PM(UTC)
Looks like the door lock is the culprit. If you can set your meter for K ohms then the normal reading should be 1.5.
sinkerking
#5 Posted : Thursday, March 29, 2012 2:18:11 PM(UTC)
sinkerking
Ok thank you. I will check that.
3 year old top loading washer won't spin clothes dry (Washer Repair)
by craig100 3/15/2024 9:35:49 AM(UTC)
Samsung washer won't spin (Washer Repair)
by Guest 1/8/2022 10:56:39 AM(UTC)
Maytag Washer won't spin or complete cycle - FIXED! (Washer Repair)
by jimjokjv 10/1/2021 10:08:04 AM(UTC)
Whirlpool WTW4815EW1 Washer Won't Spin or Agitate (Washer Repair)
by dann1551 4/7/2021 8:42:00 AM(UTC)
Maytag performa washer won't spin. It drains and i can hear the motor but tub appears stuck. (Washer Repair)
by Brittrepairs 12/21/2019 7:47:28 PM(UTC)
Whirlpool LSN2000LW Washer Won't Spin, Buzzes (Washer Repair)
by Robb235 2/21/2019 4:21:02 AM(UTC)
Washer won't spin out. (Washer Repair)
by DJChad818 10/26/2017 9:47:20 AM(UTC)
Washer won't spin (Washer Repair)
by Fingers123 10/22/2017 1:43:41 PM(UTC)
Washer Won't Spin (Washer Repair)
by je00409 9/5/2017 11:00:04 AM(UTC)
Washer won't spin or agitate (Washer Repair)
by dhughes 4/1/2017 10:17:04 AM(UTC)
Whirlpool belt drive washer won't spin. (Washer Repair)
by weswoodallz21 3/21/2017 7:08:08 AM(UTC)
Maytag Washer won't Spin just Hums (Washer Repair)
by bnweth 1/4/2017 8:29:35 PM(UTC)
Whirlpool washer won't spin or drain (Washer Repair)
by ronaldjp1 1/3/2017 2:58:09 PM(UTC)
maytag washer won't spin fast (Washer Repair)
by benp1 12/21/2016 5:14:31 PM(UTC)
by lmhansgen 8/31/2016 10:19:23 AM(UTC)
