rherm52
#1 Posted : Sunday, March 11, 2012 6:40:15 AM(UTC)
rherm52
My dryer has been squeaking for a few weks now I can not find the manual that came with it. I have been told that it is probably the Drum bearing. Can this be repaired by me or does it need a specialist and where and how would I get to the bearings. Without manual I am not sure.
JW Webster
#2 Posted : Monday, March 12, 2012 1:10:50 PM(UTC)
JW Webster
The drum rides on a central bearing with a plastic sleeve mounted between the metal mount and the drum mount. That plastic sleeve gets thin and begins to make a squeak squeak sueak when it gets thin. You do not have to buy a complete kit you can buy a bearing alone if the mounts is not worn out. Some folks allow that squeal to go on untill the whole thing goes south OUCH!
A few repair pix
JW Webster
#3 Posted : Monday, March 12, 2012 1:11:57 PM(UTC)
JW Webster
JW Webster
#4 Posted : Monday, March 12, 2012 1:14:37 PM(UTC)
JW Webster
JW Webster
#5 Posted : Monday, March 12, 2012 1:16:29 PM(UTC)
JW Webster
JW Webster
#6 Posted : Monday, March 12, 2012 1:18:33 PM(UTC)
JW Webster
The drum has got to come out to replace this part. To do so you pop the top and remove the front panel then get the belt off the idler and remove the drum. Get what is left of the old bearing out the hole and mount the new one on there. Nothing to it.:D
Electric dryer squeaking, squealing, and screaming. (Dryer Repair)
by Kurtzero 1/11/2018 4:26:56 PM(UTC)
Frigidaire Dryer squeaking (Dryer Repair)
by Gene.Dixon 9/22/2014 1:06:50 PM(UTC)
GE Harmony Dryer squeaking (Dryer Repair)
by kurtd 5/16/2014 4:34:32 AM(UTC)
GE gas Dryer Squeaking and now grinding (Dryer Repair)
by firefly 8/29/2012 8:31:09 PM(UTC)
Frigidaire Dryer Squeaking (Dryer Repair)
by rgrandmaison5@gmail.com 3/18/2012 6:19:24 PM(UTC)
Dryer squeaking when spinning (Dryer Repair)
by Geno Altiery 11/25/2011 5:16:35 PM(UTC)
Maytag Dryer Squeaking and Timer Problem (Dryer Repair)
by Bob M 8/6/2011 11:08:23 AM(UTC)
Dryer Squeaking loudly (Dryer Repair)
by tculler 3/16/2011 4:51:02 PM(UTC)
Maytag Dryer Squeaking (Dryer Repair)
by mikecno 2/22/2011 7:31:17 AM(UTC)
by toolguy47 9/21/2010 5:58:40 PM(UTC)
by DOAinNY 7/6/2010 5:01:31 PM(UTC)
GE Electric Dryer Squeaking then not rotating (Dryer Repair)
by kenro 11/28/2009 6:27:03 AM(UTC)
Amana dryer squeaking (Dryer Repair)
by Barry Briggs 11/5/2009 9:30:37 AM(UTC)
Duet Dryer Squeaking (Dryer Repair)
by cdelonis 5/24/2009 10:19:11 AM(UTC)
Electric Dryer Squeaking (Dryer Repair)
by gander 1/29/2009 6:24:52 PM(UTC)
