rgrandmaison5@gmail.com
#1 Posted : Sunday, March 18, 2012 6:19:24 PM(UTC)
Hi, I've searched a lot of posts, but couldn't find any related to my dryer. The dryer squeaks as it starts, but when heated its fine. Also, doesn't squeak when its empty.. Any idea on what's causing it and how to repair it.. Thank you in advance..
#2 Posted : Monday, March 19, 2012 10:14:28 AM(UTC)
Thank you for the response. What type of lubricant should I use and any instructions out there on to access those parts on that dryer?
Thank you,
Simon / APP Team
#3 Posted : Monday, March 19, 2012 10:51:56 AM(UTC)
Simon / APP Team
Groups: APP Team
Hello.
Here is hi temp lubricant, recommended by manufacturer.
The lubricant Part number: AP2147006
The drum support rollers usually don't need lubrication, but a tiny drop of WD40 is OK.
Here are the breakdown diagrams and Replacement parts for Frigidaire AEQB6000ES0 Frigidaire/dryer | AppliancePartsPros.com
Thank you.
#4 Posted : Monday, March 19, 2012 11:05:52 AM(UTC)
Thank you... trying to understand something, am I able to lubricate the bearing by applying it right inside the drum, just by opening the door? Or do I need to take the top off the dryer to access these parts?
Simon / APP Team
#5 Posted : Monday, March 19, 2012 11:45:41 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
You will have to take the top off.
Thank you.
Frigidaire Dryer squeaking (Dryer Repair)
by Gene.Dixon 9/22/2014 1:06:50 PM(UTC)
