2 Pages<12
mtovar
#11 Posted : Sunday, February 26, 2012 11:04:26 AM(UTC)
mtovar
The freezer seems to be cooler again, but it seems like it it cycles between warmer and cooler. Is there some sort of timer that could be bad and if so is this something that we could do?
#12 Posted : Sunday, February 26, 2012 12:11:40 PM(UTC)
That changes the picture entirely. You might have a intermittent control module in this. If you have a meter you could check.You also could have a compressor overheating and shutting down. Just observe what is not running when it gets warmer.
mtovar
#13 Posted : Sunday, February 26, 2012 12:52:28 PM(UTC)
mtovar
If we bought an intermittent control module, would it be too difficult or dangerous for us to replace ? I looked on the part list and only saw a icemaker control module. Is that the part we might need? Could you possibly direct us in the removal and installation of the module? My husband has enough tools for the job and could probably figure it out with some help.
#14 Posted : Sunday, February 26, 2012 3:57:57 PM(UTC)
It needs to be confirmed you have a bad control module part 8201660 I still feel you have refrigeration problems. If I where there, I would measure the evaporator temperature with my laser thermometer, would tell the status of the system.
If you have a thermometer,measure the lowest freezer temperature and post.
firevato
#15 Posted : Wednesday, February 29, 2012 11:27:31 AM(UTC)
firevato
I have a Kenmore refrigerator with freezer on top. Frig is working fine but freezer is not. I can hear the motor running in the freezer. What should I check next?:confused:
#16 Posted : Wednesday, February 29, 2012 1:39:24 PM(UTC)
What is the complete model nu8mber of the refrigerator?
What are exact measured temperatures in both compartments?
Can you a frost on the rear panel in the freezer?
Kenmore refrigerator/freezer issue (Refrigerator & Freezer Repair)
by rgbradley58 1/30/2024 6:32:20 AM(UTC)
Kenmore Refrigerator Model 111.72695911 Inverter Board (Refrigerator & Freezer Repair)
by jppreble 11/2/2023 2:34:22 PM(UTC)
Kenmore refrigerator model#106.59592992 (Refrigerator & Freezer Repair)
by Guest 5/16/2023 12:53:20 PM(UTC)
795.71073.013 Kenmore Refrigerator - Water leaking in the bottom freezer (Refrigerator & Freezer Repair)
by shreshtluthra 3/16/2023 10:21:43 AM(UTC)
Kenmore Refrigerator trips GFCI (Refrigerator & Freezer Repair)
by A_A_Ron 7/1/2022 11:38:52 AM(UTC)
Kenmore refrigerator breathing (Refrigerator & Freezer Repair)
by Guest 1/3/2022 3:24:07 AM(UTC)
Reading codes from Kenmore Refrigerator (Refrigerator & Freezer Repair)
by caribconsult 11/29/2021 3:18:54 PM(UTC)
Kenmore refrigerator 'ER - dH' code (Refrigerator & Freezer Repair)
by Kanehs 9/22/2020 9:47:19 PM(UTC)
Kenmore Refrigerator Ice Crusher (Refrigerator & Freezer Repair)
by JOSHSKORN 4/27/2020 11:48:08 AM(UTC)
Kenmore refrigerator 3 beeps (Refrigerator & Freezer Repair)
by bluefitness 3/3/2019 5:37:06 AM(UTC)
Kenmore refrigerator: 106.64252402 (Refrigerator & Freezer Repair)
by SGH 1/1/2019 12:39:12 PM(UTC)
Kenmore Refrigerator Pooling Water on Floor (Refrigerator & Freezer Repair)
by vintess 2/17/2017 5:18:47 PM(UTC)
Kenmore Refrigerator not cooling (Refrigerator & Freezer Repair)
by Doug615 5/14/2016 12:27:12 PM(UTC)
Kenmore refrigerator not dispensing water into ice tray (Refrigerator & Freezer Repair)
by Jmfreddy17 1/6/2016 3:10:02 PM(UTC)
Filler tube for Kenmore refrigerator (Refrigerator & Freezer Repair)
by kidcapri73 6/24/2015 2:41:34 PM(UTC)
2 Pages<12
