318881
#1 Posted : Wednesday, November 17, 2010 9:18:55 PM(UTC)
318881
Dryer makes squealing noise every time used. Noise is intermittent.
Diagnosis please. Do you have recommended website for part and installation instruction? What is normal life of washer/dryer? At 13 years am I better off replacing vs repair?
Thank you in advance.
#2 Posted : Friday, November 19, 2010 1:11:36 AM(UTC)
Replacement parts for FSE7477GES0 models | AppliancePartsPros.com
Here is a manual which should help with the repair.
http://frigidaireservicetips.com/pdfs/488_3.pdf
Whether is is worth repairing depends on what is wrong with it, may just need some grease on the drum bearing. New units are usually not built as good as the old ones.
Squeak could be a number of things. Listen carefully to see if you can get an idea of where it is originating.
Could be the motor bearings, the idler pulley, the front glides or the rear drum bearing.
Most common is the rear bearing.
Open the unit up and check parts for wear and slop.
Also check the belt.
Replace as necessary.
Also check all internal seals.
Might as well give it an overhaul.
When re-lubing the rear bearing be sure to use a high temp grease.
Give the interior a good clean including the blower wheel.
Also clean/check your vent system.
Here is a good site with general dryer repair info.
http://www.applianceaid.com/dryers.html
Ge dryer will not stay on (Dryer Repair)
by Guest 5/10/2024 3:25:16 PM(UTC)
GE dryer timer issue (Dryer Repair)
by Guest 5/8/2024 11:47:16 AM(UTC)
Amana electric dryer not working (Dryer Repair)
by Guest 5/3/2024 10:43:01 AM(UTC)
Kenmore Electric Dryer 110.65132411 (Dryer Repair)
by Guest 5/1/2024 5:58:30 AM(UTC)
WGD8410SW0 Dryer l (Dryer Repair)
by Hkfmike 4/27/2024 6:00:13 PM(UTC)
1998 Maytag Gas Dryer Drum Issue Has Me Stumped (Dryer Repair)
by semaas 4/22/2024 9:44:18 PM(UTC)
Whirlpool gas dryer model WGD8300SW2 (Dryer Repair)
by Guest 4/20/2024 7:14:50 AM(UTC)
WED4815EW1 Dryer overheating? (Dryer Repair)
by Guest 4/16/2024 12:21:03 PM(UTC)
DLEX5780WE lg dryer shutting off before the clothes are dry. (Dryer Repair)
by LMA 4/13/2024 11:00:21 AM(UTC)
help maytag comercial dryer (Dryer Repair)
by blackwell316 4/4/2024 5:05:48 PM(UTC)
grease for rear dryer bearing (Dryer Repair)
by bronn033 3/30/2024 12:57:30 PM(UTC)
Kenmore Gas Dryer Running Hot (Dryer Repair)
by Guest 3/30/2024 6:24:53 AM(UTC)
Kenmore 100 dryer Heating Element (Dryer Repair)
by postalservice21 3/27/2024 6:43:17 AM(UTC)
Maytag electric dryer model MDE6400AYQ (Dryer Repair)
by Guest 3/25/2024 10:05:21 AM(UTC)
GE Dryer Timer and Housing (Dryer Repair)
by Guest 3/25/2024 7:47:59 AM(UTC)
