mrmrst
#1 Posted : Tuesday, April 21, 2009 10:24:22 AM(UTC)
mrmrst
I can't find the owners manual to trouble shoot the problem. There is water in the bottom after running that isn't draining out. Is there somewhere where something may be clogging?
Thank you
#2 Posted : Tuesday, April 21, 2009 1:48:30 PM(UTC)
The first thing I would check is the air gap (on top of the sink) for a plug.
If there is nothing wrong then disconnect the drain hose from the air gap and put it in a bucket. If there is no air gap and the drain hose is connected straight to the garbage disposer then disconnect it and put the hose in a bucket. Run the dishwasher and see how it'll drain. Post the results.
Here are the breakdown diagrams and Replacement parts for MAYTAG MDB4100AWW | AppliancePartsPros.com
washer water not draining (Washer Repair)
by mwashbu 10/21/2019 2:14:42 PM(UTC)
Water not draining (Washer Repair)
by macismom 2/28/2014 2:40:48 PM(UTC)
by kyarbrough5@cox.net 7/15/2012 5:04:08 PM(UTC)
water not draining (Dishwasher Repair)
by dsbowler 7/9/2012 9:19:24 AM(UTC)
by hillestad 12/29/2011 9:09:22 PM(UTC)
Came home to burnt rubber smell and water not draining from Washer (Washer Repair)
by kota701 12/8/2011 11:27:57 AM(UTC)
Water not Draining (Washer Repair)
by ccino1 10/26/2011 7:38:45 PM(UTC)
Water not draining after new pump was installed (Dishwasher Repair)
by lloyd520 12/29/2010 4:44:42 PM(UTC)
water not draining completely (Dishwasher Repair)
by ronmer 5/5/2010 6:51:43 AM(UTC)
by image252 2/9/2009 10:48:51 AM(UTC)
Washer water not draining from rinse cycle (Washer Repair)
by Michaele 11/24/2008 3:21:47 AM(UTC)
