macismom
#1 Posted : Friday, February 28, 2014 2:40:48 PM(UTC)
macismom
Hi! Here's my situation:
My washer had been running all morning (5-6 loads). Then when I went to switch, the cycle was at off, but water was still in the tub.
At that point, the washer would not respond at any point on the dial. After I waited an hour thinking the motor might have overheated, the washer did work when I turned it back to a spin cycle, but the same thing happened and the water did not drain. (Just fyi...the dryer was running at the time the washer stopped so I know it is getting 220v.)
I would appreciate any guidance as to how to fix this asap. I have deduced that I may have clogged my drain pump, but I can't seem to find any pictures online or demonstrations to show/tell me how to even find the pump. I can answer any other questions or give any details I can. Thanks!!!
Melissa
sidfink43
#2 Posted : Sunday, March 2, 2014 5:41:37 AM(UTC)
sidfink43
On these models a small article of clothing often clogs the drain hose coming from the tub to the pump.
At the bottom of the front panel are two screws that will allow you to take off the front panel. After that you will be able to see how to disconnect the hose to the pump and check out the pump and the hose. Also check the drain from the pump to the drain pipe and the drain pipe itself.
Somewhere in their you should find your problem. If not, check the pump itself.
washer water not draining (Washer Repair)
by mwashbu 10/21/2019 2:14:42 PM(UTC)
Water not draining (Washer Repair)
by kyarbrough5@cox.net 7/15/2012 5:04:08 PM(UTC)
water not draining (Dishwasher Repair)
by dsbowler 7/9/2012 9:19:24 AM(UTC)
by hillestad 12/29/2011 9:09:22 PM(UTC)
Came home to burnt rubber smell and water not draining from Washer (Washer Repair)
by kota701 12/8/2011 11:27:57 AM(UTC)
Water not Draining (Washer Repair)
by ccino1 10/26/2011 7:38:45 PM(UTC)
Water not draining after new pump was installed (Dishwasher Repair)
by lloyd520 12/29/2010 4:44:42 PM(UTC)
water not draining completely (Dishwasher Repair)
by ronmer 5/5/2010 6:51:43 AM(UTC)
Water not draining (Dishwasher Repair)
by mrmrst 4/21/2009 10:24:22 AM(UTC)
by image252 2/9/2009 10:48:51 AM(UTC)
Washer water not draining from rinse cycle (Washer Repair)
by Michaele 11/24/2008 3:21:47 AM(UTC)
