ccino1
#1 Posted : Wednesday, October 26, 2011 7:38:45 PM(UTC)
ccino1
Code appeared on my initial service mode. Checked my pressure switch connection, things looks physically ok, even when I tried to suck through the tube...it opens the line. Tried to spin & heard my drain pump sloshing the water but not a whole lot will come out. Time display is not progressively counting down but will go up a notch then down a bit.
Pls. advice and where can I buy the part?:confused:
sidfink43
#2 Posted : Friday, October 28, 2011 5:42:49 PM(UTC)
sidfink43
It is hard to say based on the info provided, but the place to start is with the drain pump. You need to check to see if it is getting current.
If you want to replace it, go to the parts section of this Site and insert your model number. You will be taken to exploded views of your machine along with the part number. You can use that info to get parts.
washer water not draining (Washer Repair)
by mwashbu 10/21/2019 2:14:42 PM(UTC)
Water not draining (Washer Repair)
by macismom 2/28/2014 2:40:48 PM(UTC)
by kyarbrough5@cox.net 7/15/2012 5:04:08 PM(UTC)
water not draining (Dishwasher Repair)
by dsbowler 7/9/2012 9:19:24 AM(UTC)
by hillestad 12/29/2011 9:09:22 PM(UTC)
Came home to burnt rubber smell and water not draining from Washer (Washer Repair)
by kota701 12/8/2011 11:27:57 AM(UTC)
Water not draining after new pump was installed (Dishwasher Repair)
by lloyd520 12/29/2010 4:44:42 PM(UTC)
water not draining completely (Dishwasher Repair)
by ronmer 5/5/2010 6:51:43 AM(UTC)
Water not draining (Dishwasher Repair)
by mrmrst 4/21/2009 10:24:22 AM(UTC)
by image252 2/9/2009 10:48:51 AM(UTC)
Washer water not draining from rinse cycle (Washer Repair)
by Michaele 11/24/2008 3:21:47 AM(UTC)
