mastertone5
#1 Posted : Thursday, April 16, 2009 3:39:56 PM(UTC)
mastertone5
Timer will not advance in auto dry modes when temp selector is on any heat. Timer will advance in auto when temp selector is on air fluff. I have changed the cycling thermostat and the the temp selector switch. Any ideas?
#2 Posted : Friday, April 17, 2009 5:58:30 AM(UTC)
Replacement parts for MAYTAG SDE305DAYW | AppliancePartsPros.com
Here is a service manual and a tech sheet
http://www.servicematters.com/m...ibrary/docs/16023020.pdf
http://www.servicematters.com/m...ibrary/docs/16023139.pdf
In permanent press with heat contacts 3 PK/BU and 4 PK/BK must be closed for the timer to advance when the Cycling Thermostat shuts the heat off.
Unplug the unit. Put it in Perm Press with heat and check that they are closed.
Might also be a broken wire, the orange one from the thermostat to the timer would be at the top of the list.
Always a possibility that the Cycling Thermostat you received is defective. Remove it heat the face up with a soldering gun or on an oven element and check that the Normally Open contacts close when the thermostat trips to off.
The timer would be at the top of the list.
peterhicks
#3 Posted : Tuesday, April 21, 2009 11:42:24 AM(UTC)
peterhicks
steps to change door switch
#4 Posted : Tuesday, April 21, 2009 2:06:40 PM(UTC)
This is a duplicated thread.
Answered here: http://forum.appliancepartspros...-repair/31073-dryer.html
Maytag electric dryer model MDE6400AYQ (Dryer Repair)
by Guest 3/25/2024 10:05:21 AM(UTC)
Maytag electric dryer model LDE9306ACE (Dryer Repair)
by Guest 3/7/2024 9:11:14 AM(UTC)
Maytag Electric dryer model MEDC300XW0 (Dryer Repair)
Belarus Guest 2/6/2024 1:56:33 PM(UTC)
Maytag electric dryer blower wheel wear (Dryer Repair)
by Guest 1/1/2024 7:44:11 AM(UTC)
Maytag electric dryer with coin type operation model MDE16CSAYW (Dryer Repair)
by Guest 6/29/2023 9:53:26 AM(UTC)
Maytag electric dryer question (Dryer Repair)
by cramerj 2/15/2021 4:59:49 PM(UTC)
Maytag electric dryer wont start (Dryer Repair)
by HammerSings 3/12/2015 5:22:07 PM(UTC)
Maytag electric dryer takes too long. Troubleshooting guide? Service manual? (Dryer Repair)
by MargretS 11/2/2014 12:08:03 PM(UTC)
Maytag Electric Dryer Light Works But Won't Turn On (Dryer Repair)
by MaytagManNC8 4/11/2014 3:21:09 PM(UTC)
Maytag electric dryer new Thermistor going bad (Dryer Repair)
by derektuan 3/25/2014 5:59:38 PM(UTC)
Maytag electric dryer (Dryer Repair)
by anniepesathor 9/3/2013 6:31:00 AM(UTC)
Maytag electric dryer won't heat (Dryer Repair)
by kspeters 2/6/2013 5:23:47 PM(UTC)
Maytag Electric dryer (Dryer Repair)
by shulskyt 2/6/2013 1:57:13 PM(UTC)
Maytag Electric Dryer won't heat up (Dryer Repair)
by rajpat25 7/7/2012 12:56:23 PM(UTC)
maytag electric dryer runs for 10 min and shuts off (Dryer Repair)
by bearsforme_22 3/8/2012 2:02:11 AM(UTC)
