wildflowerpa
#1 Posted : Friday, June 3, 2011 11:20:39 AM(UTC)
wildflowerpa
I have a roper top loading washer that sometimes won't spin out all the water. Other times it works fine and spins out all the water. I have looked for a model number and the numbers I have found aren't the right ones. thanks
Joe / APP Team
#2 Posted : Friday, June 3, 2011 1:43:06 PM(UTC)
Joe / APP Team
Wildflowerpa,
hopefully, this is a newer "direct drive" washer.
After you check the drain hose for kinks and clogs, and make sure the drain hose is not sealed to the standpipe, and the drain system is clear.
You'll need to remove the washer cabinet, and remove the drain pump and check the pump and hoses for clogs and kinks, as wellas the drive hub on the pump for free movement or noise.
1. Remove
the two Phillips-head screws securing the front corners of the console to the washer top.
(There are other locations as well on the back side of the end caps of the control panel, under the front end cap panel, and you may have spring loaded clips on the bottom of each end cap).
2. Tip the console back on the hinges that secure the top of the console to the washer back.
ACCESSING COMPONENTS INSIDE THE WASHER CABINET
Components inside the washer cabinet can be accessed by completely removing the outer cabinet as one unit.
1. Remove the console mounting screws and tilt the console into the service position.
2. Unplug the lid switch harness connector from the receptacle in the washer top.
3. Remove the cabinet mounting clips by placing the flat blade of a screwdriver in the clip.
Push down and pry out at the same time on the front end of the clip
4. Remove the cabinet by tilting it forward and pulling it away from the washer.
5. The rear panel can be tilted back for additional access to components at rear of machine.
The pump is mounted to the motor by 2 spring clips, remove the clips and slide the pump off the mounting tabs and motor shaft.
There will be water left in the pump and hoses, so be ready for spillage.
Hopefully, this will get you where you need to be.
wildflowerpa
#3 Posted : Friday, June 3, 2011 3:56:49 PM(UTC)
wildflowerpa
Thanks for the help. I'll get back to you on how it goes.
Joe / APP Team
#4 Posted : Monday, June 6, 2011 5:05:58 AM(UTC)
Joe / APP Team
OK,
We'll keep an eye out for your next post.
Roper washer RAL5144BQ1 (Washer Repair)
by Nanabkim 2/16/2024 2:16:15 AM(UTC)
Roper washer will not run (Washer Repair)
by Guest 12/10/2023 10:53:47 AM(UTC)
Roper Washer Cycle not Going Past Wash (Washer Repair)
by Guest 5/31/2022 7:14:14 AM(UTC)
Roper Washer RAX6144EW1 (Washer Repair)
by mtwheeler 6/14/2021 2:55:09 PM(UTC)
Roper washer RTW4640YQ1 out of balance (Washer Repair)
by seagypsy 10/3/2020 5:00:03 PM(UTC)
Roper Washer spin ballance banging wobbling (Washer Repair)
by Braum 9/29/2019 7:51:52 PM(UTC)
Roper washer will agitate instead of filling at the beginning of the cycle (Washer Repair)
by wilkimtur1 2/11/2018 7:56:25 AM(UTC)
roper washer wont go to rinse cycle (Washer Repair)
by stevencurtiss 2/25/2017 7:19:56 AM(UTC)
Roper washer making awful noise during agitate and spin (Washer Repair)
by Michaelk24 2/8/2017 6:00:25 PM(UTC)
Roper Washer no Start (Washer Repair)
by bellmd 1/21/2017 6:08:14 AM(UTC)
Roper Washer Walks Counter Clockwise (Washer Repair)
by RunawayRoper 10/14/2016 3:47:34 PM(UTC)
Roper washer (Washer Repair)
by Mike Newberry 8/6/2016 7:44:22 PM(UTC)
Roper Washer spins but doesn't spin enough water out (Washer Repair)
by tomanypups1 7/24/2016 7:14:54 AM(UTC)
Roper washer fills with water then nothing else (Washer Repair)
by faunwin12 5/14/2016 6:20:49 AM(UTC)
Roper washer not completing rinse cycle (Washer Repair)
by Drumm3rboy07 1/1/2016 9:19:17 PM(UTC)
