When I turn my oven on it say's it's already 200 degrees and want heat up.Could this be the oven sensor or key pad ? I can turn to 500 and it gets about 250 degrees in oven.
[FONT='Times New Roman'] The sensor is the most likely problem. The sensor should have about 1000-1100 ohms a room temperature. Oven Repair Guide[/FONT]
Originally Posted by: applianceman The sensor is the most likely problem. The sensor should have about 1000-1100 ohms a room temperature. Oven Repair Guide I replaced sensor and it does the same
Replaced sesor and that didn't fix the problem
