Originally Posted by: alanp My son was using the dryer, it poped the groung fault. We reset it and it poped right away. We moved the dryer to another plug and as soon as you plug it in the ground fault will pop. What is wrong?
Alan,
You have a shorted line wire(120 VAC) shorted to the chassis ground.
You need to start at the power cord, and work your way through the wiring harness, until you find the short.
With the power cord unplugged,
Remove the 2 screws that secure the console to the top(bottom corners of the console).
Lay the console on the dryer top and remove the screws that secure the back panel to the console.
To raise the top, remove the lint filter, and the 2 screws securing the filter housing to the top. with a putty knife or simillar tool, push in on the 2 spring clips, located in the seam between the top and front panel, approximately 3 inches in from the corners, and lift the top up.
Remove the lower access panel and disconnect the door hinge springs,and loosen the 2 screws holding the bottom of the front panel to the cabinet.
Remove the 1/4 in screws holding the front panel to the frame, approximately 3 in. down on the inside of the front flange. Pull out at the top of the front panel, disconnect the door switch wires, and raise up and out on the front panel to remove.
Dismount the belt from the motor and idler pulley(take a note of belt routing for reinstallation)and lift drum slightly up and out of cabinet.
You'll have access to all the wiring in the unit, and should be able to find the short from there.
